Results 1 to 4 of 4
Thread: Powering Mobile TV M5000
    Aug 2004
    Brookville, IN
    I believe this is a newbie question, if for no other reason than the fact that I don't know whether it would belong in the Power or the Display forum. That makes me a newbie, right?
    Anyway, I have a 5 inch mobile tv lcd screen that I'm going to be using for my carpc until I magically become rich. It is a composite in screen, but hopefully it will be sufficient to display a little MP3 info and the like.
    My question is how I should power the screen. It has a power connector built into the breakout box for the video inputs, which is then connected to the actual screen through another cable. I've attached pictures of the connector socket and the pinout diagram. I'm running an old desktop ATX power supply and an inverter. Could somebody instruct me on the best way to get power to the screen? Thanks.
    Nov 2004
    NYC
    You don't have to use the remote out wire. You only need to supply +12v for the acc and battery lines. If you are going to use your ATX power supply for this, you can use the yellow wire on the molex connectors coming out of the power supply. You can also use the ground right next to the yellow wire from the same connector.
    So on the screen power connector, the yellow wire from the molex connector will be connected to both the acc and battery lines. The ground line.... I'll let you figure it out.
    Aug 2004
    Brookville, IN
    Alright, thanks very much. That seems easy enough.
    Apr 2005
    I have this same tv and need help
    i need to find the cable that connects this unit to the dvd and power connector... the MOBILE TV M5000 has a cable that comes out with what looks like a s-video connector but has 9 holes.. how can I connect it..d oes anyone have a diagram or any info please email me at lep136@hotmail.com
    thank you...
    for your genius minds.
  1. 5.6 LCD screen Never Installed Mobile TV
    By Explorer5.0 in forum Classified Archive
    Last Post: 11-12-2004, 10:05 AM
  2. Splitting one VGA to 3 LCD and TV output
    By lookinco in forum LCD/Display
    Last Post: 09-26-2004, 06:19 AM
  3. Mobile TV
    By slammedblazer09 in forum LCD/Display
    Last Post: 02-10-2004, 11:12 PM
  4. Replies: 3
    Last Post: 05-02-2003, 07:29 PM
  5. powering a mobile computer
    By outragis in forum Power Supplies
    Last Post: 10-26-2002, 04:27 PM
