Results 1 to 7 of 7
Thread: Turn off check disk in XP
    Low Bitrate cyber's Avatar
    Jun 2004
    Frozen Tundra
    I've finally discovered how to keep XP from running check disk on startup after a non-graceful shutdown (all you fellow POS ITPS owners know what I'm talkin about). This is a registry modification:
    HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Contro l\Session Manager
    REG_MULTI_SZ: BootExecute=""
    with the autocheck autochk * removed you'll no longer be bothered with check disk.
    enjoy
    Maximum Bitrate GruvThang's Avatar
    Jul 2004
    Northern Virginia, USA
    nice find, where did you find it?
    [COLOR=Navy][SIZE=1][FONT=Comic Sans MS]Tektility
    Jun 2004
    Frozen Tundra
    actually I found it myself while trying out a regedit I found googling that didn't work. I forget the key but it was a DWORD that basically modified the time you have to hit a key to skip the check disk and the site claimed setting it to 0 disabled check disk...nope just eliminated my chance to skip the check. It just happened to be in the same location as the BootExecute key. I figured what the hell, I'll delete the contents and see what happens
    Jul 2004
    S.M.R.T.
    good job!
    Elsewhere
    Quote Originally Posted by cyber
    enjoy
    It's your data....
    How about the Wiki?
    Raw Wave hijinks21's Avatar
    May 2002
    Albany, NY
    if you have a ntfs filesystem.. it shouldn't do a check anyway since its a journled filesystem.. or so i think
    '98 Explorer Sport
    80% done
    Jun 2004
    Frozen Tundra
    Quote Originally Posted by DarquePervert
    It's your data....
    sure is I didn't say its a good thing to do but it can be done if you wish to do so
  1. XP on CF II Drive
    By NOS TANG in forum Software & Software Development
    Last Post: 11-30-2004, 02:20 PM
  2. Coyote check this out...
    By ShawJohn in forum MediaCar
    Last Post: 09-06-2004, 09:29 AM
  3. Lilliput & Win XP pro !!!! problem
    By vicky_obee in forum LCD/Display
    Last Post: 07-05-2004, 10:12 PM
  4. Hard disk mounting - my thoughts
    By gizmomkr in forum General Hardware Discussion
    Last Post: 01-12-2001, 02:35 PM
  5. How do you turn off scan disk?
    By sleddog4 in forum General Hardware Discussion
    Last Post: 12-09-1999, 10:03 PM
