Results 1 to 10 of 10
Thread: Power Supply for a full size computer
    Newbie After_Forever's Avatar
    Nov 2004
    I am looking to put a full size P4 computer into my Suburban. I think I have everything figured out in my head except for the power supply unit. I have looked through these forums a bit but can find much about the power supplies. I read that others are using Opus supplies. After reading through this site that sells Opus supplies and reading the FAQ. I see that it says “The power supplies we sell are specifically designed for mini-ITX motherboards”. Would someone enlighten me as to what supply to use? I do not want to use an AC/DC converter, way too much power loss.
    Thanx
    After Forever
    Btw: what is a mini-ITX motherboard? How does it compare to a P4? Don’t want to go that route!
    Aug 1999
    Washington D.C.
    ITX is a form factor (size) of the motherboard. They usually have embedded processors. The OPUS 90 watt http://www.mp3car.com/store/product_...products_id=30 is good power supply for this form factor.
    How fast is your P4? The problem is that the latest scramming P4's will draw too much power for the current dc-dc power supplies available today. When you have a really fast system like that your best bet is the DC/AC inverter method with a regular AC/DC computer power supply.
    Low Bitrate joebagodoe's Avatar
    Oct 2004
    Kansas City, MO, USA
    SO, before I go out and blow more money on this god forsaken project, my (Rockford Fosgate) 300w inverter does not power my computer (mATX, 2400+, 240w PS, 1 - 120GB, 512m ram). The computer doesn't even turn on! I'm guessing that the inverter is just not powerful enough, or that my mobo has a feature that detects non-standard power and just won’t turn on. It's an AOpen MK79G-N and if I spend any more money on this, my wife may literally kill me. Getting in to this, I never would have imagined that I'd be spending so much. I just want it to frickin work!
    Today I stuffed some dolls full of dead rats I put in the blender. I'm wondering if maybe, there really is something wrong with me.
    Aug 1999
    Washington D.C.
    Quote Originally Posted by joebagodoe
    Inverters are rated for their peek output. Their normal outputs are half of that. A 300 watt inverter would put of 150 watt. Look for at least a 600 watt inverter to power your 240 watt computer power supply.
    Oct 2004
    I just went and bought a 750w "Vector" inverter (stated peak was 1500w) that came with 8aug battery clamps. I connected it up with the engine off and then with the engine on, but neither way would power the power supply. The red light on the inverter flashed (over volt/low batt) when I plugged the computer in. Odd problem wouldn't you say!
    Oct 2004
    Maybe I should somehow test the PC to see the current draw? Maybe the pull from it is jacked in some manner? Too many amps?
    Low Bitrate nrls2000's Avatar
    Oct 2004
    Nebraska
    750w vector should be ample power...check your power supply connections and possibly the power supply itself.
    Is the vehicle running when you plug in the computer?
    If yes, what is the voltage at the inverter?
    Does the inverter make a whining noise when the red light turned on?
    Oct 2004
    It did this with a 350w (700w max) Vector inverter I bought today too.
    Vehicle was running while I tested it.
    My alternator puts out >13.7, is it ok to put a multimeter on a battery to see the current?
    no noise from the inverter.
    And I re-connected after failure to ensure good connection
    FLAC bosstone74's Avatar
    May 2002
    Japan, Oregon
    this might be a fix....
    I had the same problem with the vector
    Inverter Problems
    remove the ground on the inside of the powersupply and attach it to the outside of the case of the power supply
    BossTone74
    Oct 2004
    Problem corrected in accordance with thread supplied above!
  1. Replies: 2
    Last Post: 08-11-2004, 11:08 AM
  2. OPUS power supply
    By xenonflx in forum Newbie
    Last Post: 11-30-2003, 06:06 PM
  3. the perfect power supply
    By agent_86 in forum Power Supplies
    Last Post: 12-08-2002, 06:39 PM
  4. More info on OPUS automotive ATX power supply
    By InvisiBill in forum Power Supplies
    Last Post: 08-16-2002, 03:19 PM
  5. HELP?! with power supply and noise!!!
    By Roadrunner in forum General Hardware Discussion
    Last Post: 11-19-1999, 02:25 PM
