Page 1 of 3 123 LastLast
Results 1 to 10 of 25
Thread: Where to store the carputer at
    Newbie chopstickman's Avatar
    Nov 2004
    Lexington, KY
    Hello, I've been trying to figure out where exactly to put a computer into my car. So far I have seen it put into the dash, the trunk, or under the seat. I am driving a SUV, so the trunk as a place to store it is eliminated because I use it a lot for sports equiptment, luggage, etc. I was wondering if putting the computer in the dash would work alright, or should I try to find some other place to put it because I am afraid the computer may overheat in the winter when I have the heat on in the car. Thank you for your advice.
    Variable Bitrate nzKAOSnz's Avatar
    Aug 2003
    Christchurch - New Zealand
    what size mobo?
    Tainted Love Cris's Avatar
    Romania
    Try the glove compartiment. Post a pic of the interior of the SUV, and the trunk. I know you said the trunk is eliminated, but you never know...
    Nov 2004
    Lexington, KY
    nzKAOSnz: I am thinking of useing a shuttle mobo, such as the SS51G off of newegg because it is fairly cheap. If there is anything smaller that will preform just as well, please tell me. Thanks.
    Cris: I will post a picture of my interior as soon as I find my digital camera, it's somewhere buried in my room. I also do not want to install in in the glove compartment, because I like to keep all my car documents and information stored in it. Thank you for the suggestion though =).
    Nov 2004
    Seal Beach, CA
    chopstick - for the same reasons as you (wanting to keep the back area for equipment, glove compartment for manuals, etc), i chose to put mine in the dash. i only got it put in a couple of weeks ago, and my dash is still in pieces while i figure out the last details, but so far it seems to be working great. and with it in the dash, i still have all the functionality of the rest of the car.
    i'll post more pics soon of the final install (probly next weekend), so keep an eye on this...
    2004 4Runner #2
    late
    2004 Toyota 4Runner Sport 4WD
    Opus 90W, Epia M210K, Lilli 7" TS, 30GB, CDR/DVD Slot, PowerMate, Earthmate, 200GB Seagate 3.5", Verizon BroadbandAccess, CentraFuse, Valetine1 .....
    Aug 2003
    "computer may overheat in the winter"????????????????????????????
    thats a new one.......
    under seat often is good. Also - in the trunk - how deep are the side walls?
    I currently eyeing up the side wall of my SW trunk.
    Also - if the car has a compartment thingy under your elbow......
    Maximum Bitrate kiltjim's Avatar
    Feb 2004
    PA, USA
    The trunk is eliminated?!? Why on earth would you do that? I drive a hatchback (alright, its a station wagon), and built a custom enclosure with a lid and everything. I lost maybe 1.5 cubic feet, which translates into a 3" rise in the trunk space. And I'm a college student which drives back and forth to school, too.
    But you know, if you wanna take the easy way out and wedge it into the dash...be my guest... (I'm kidding, seriously!)
    2000 Subaru OBS
    Dell P3 @ 900 Mhz
    7" Lilliput TS w/DigitalWW in-dash mount
    80GB External HD
    I am Zero Bitrate....
    Maximum Bitrate yunusyu's Avatar
    May 2004
    Hollywood
    There is no place better than under the seat!
    Reasons:
    1- If something goes wrong, you can reach in and lets say unplugg or something.
    2- the wires are easier to run - i think -
    3- DVD player can be attached inside the compartment between the seats. and if you want you can actaully run the IDE cable to it (but usb is cleaner)
    4- put a neon light in the box and make a window, so if anyone asks "what is this"!!! roll up the seat and TADA...trust me happens quite a bit
    5 - Easier to remove
    6- good ventilation, cold air is usually closer to the floor in the cabin
    BTW we will soon release a box that is design only for mini ITX and opus and 3.5 hD, so you might want to get all your parts from MP3CarSTORE of course, and wait for like 2 weeks wehn we release...if u wnat to wait, good luck
    BTW remove the four screws that hold the seat in, it makes the job SO much easier..
    hope you decide to do this
    In dash is cool, and fun, but have limitations, like upgrading...unless anyone thinks otehrwise, i would like to know why
    DICE Los Angeles
    Variable Bitrate Supermike's Avatar
    May 2004
    AZ
    Chopstick - I have a 2000 Pathfinder and installed my carputer in the dash. It is VERY tight and I would not recommend it. There were some benefits to the dash, but they are outweighed by the problems with servicing the computer. In fact I am now looking to move it to a more accessible location since it requires about 1 hour of work for install and removal.
    There are several places that seem to be candidates. There is a compartment in the floor under the carpet near the tailgate. It is out of the way, but had no ventilation - so is not a good option - though it could be vented outside or inside with some work.
    The second option is the compartment in the rear passenger side. This seems ideal since it has plenty of room for an ITX board and power supply, the only con is that it is far from the front, so cables will need to run further.
    Another possible option is the front center armrest console but that will require more hacking that I want to do (don't want to ruin the resale). Under the seat would be too tight IMHO.
    I am currently investigating the compartment in the passenger side rear quarter. Potential problems with this for me are that I want the CD up front and therefore will need to convert it to USB, and the cables will need to be extended and run to the front where the LCD is mounted. My goal is to make the whole thing easy to remove and service.
    If you come up with a solution that I did not mention, please let me know since I am going to re-install my system soon.
    "Protecting Privacy and Free Speech Online"
    http://www.eff.org/
    Nov 2004
    Has anyone considered making a false floor on the passenger side and carpeting it. With a floor mat you wouldn't even notice or miss the 3 or 4 inches.
  1. 99 Acura TL carputer project pics
    By Darkshear in forum Show off your project
    Last Post: 08-23-2007, 01:14 AM
  2. carputer install: I dare you...
    By Cat Monkey in forum General MP3Car Discussion
    Last Post: 01-27-2005, 06:34 PM
  3. Replies: 9
    Last Post: 10-23-2004, 03:25 AM
  4. Replies: 4
    Last Post: 02-16-2004, 10:08 AM
  5. How to build your carputer at a liquor store
    By C4M in forum General Hardware Discussion
    Last Post: 09-14-2002, 03:45 AM
