Page 1 of 3 123 LastLast
Results 1 to 10 of 26
Thread: can noise be the cause of cheap RCA cables?
    May 2004
    so im using those headphone to rca adapters. and the rca im using is those cheap black ones.
    ive grounded my itps and lilliput properly, even sanded the spot.
    i think i need to get GOOD RCA CABLES + ADAPTER (headphone) ?
    May 2004
    anyone?
    Newbie popuptoaster's Avatar
    Aug 2004
    Essex, UK
    i would say no, but, i would say that noise can be caused by cheap RCA cables! LOL
    seriously, cheapo cables can be a bit marginal on the sheilding side, usually ok for home use where there is far less electrical noise. also make sure you RCA cables are as far away from any power wiring as possible.
    May 2004
    Quote Originally Posted by popuptoaster
    hmmm. how would i do this if my mobo is under my stock deck (in-dash carputer)
    Maximum Bitrate GruvThang's Avatar
    Jul 2004
    Northern Virginia, USA
    Quote Originally Posted by chicochu
    Make sure you are not using a 6ft cable looped around the blower and back! Make it neat, coiled up with twist ties or even better zip strips.
    Why even use cheap cables? Just get some nice ones they will be better in the long run anyway. Either way you will have to keep the cables neat. Try to get only as much as you need to eliminate excess looping.
    [COLOR=Navy][SIZE=1][FONT=Comic Sans MS]Tektility
    May 2004
    Quote Originally Posted by GruvThang
    sorry what do you mean by 'looped around the blower and back!' ???
    Nov 2004
    The answer is yes.
    Yes, you will probably hear noise if you are using RCA cables (especially cheap ones). Because RCAs are analog, they are picking up all the EMI being generated by your engine. There are two ways go loose the EMI.
    1. Use a digital signal to carry your audio (USB works). You will probably have to find an external auxillary input unit which will work with your deck (since I haven't seen the brillant idea of putting USB audio input on a deck). EMI does not interfere with a digital signal, so the audio is crystal clear.
    2. Put your computer close to your deck and use very short high quality RCA cables.
    Cheers
    May 2004
    Quote Originally Posted by selzier
    Cheers
    hey you seem to know what ur talking about.
    i have a AUX-in adapter that takes in RCA (red/black)
    i know where to get high quality RCA, but where do i get quality RCA-to-headphone adapters?
    also? ur saying that option #1 is impossible since there is no aux-in usb adapters?
    Nov 2004
    More info...
    Is the headphone adapter coming out of your sound card?
    If so, use 1 cable with headphone (1/8'' audio) on one end, and RCAs on the other end.
    1/8 plug ------------------- RCAs
    Skip the RCA to 1/8'' adapter, because that is just more unshielded ends to receive EMI. You said your computer is right under your deck, so if you are really paranoid you can buy that cable, cut it as short as possible, and wire it back together (use teflon tape and tin foil as a shield). The more cable you have, the more EMI you are gonna pick up.
    You can buy an external auxillary input adapter (like the one you have) with USB or Optical S/PDIF inputs. Optical will work as well, since it is not analog.
    Oct 2004
    Remember to cross power / signal at 90 degree intersections if they have to cross at all. Magnetic fields in power wires are tiny, you won't be affected unless they are absolutely touching. You don't need GOOD rca's, just get something shielded. Ground the shielding. Also, your noise is probably a gain/signal impedence problem. Put something between your computer and your amps if its really bad. I'm assuming thats what you have hooked up, since you didn't tell us anything. Sound cards don't put out the same kind of signal that your amps were designed to take. Voltage is too low, you're cranking the amp, etc. Try a line driver, use audiocontrol, they make great stuff.
  1. FS: Lilliput RCA cables, memory
    By PaCMaYNE in forum Classified Archive
    Last Post: 10-24-2004, 07:27 PM
  2. Making LONG RCA cables for interior walls?
    By bosstone74 in forum General Hardware Discussion
    Last Post: 09-05-2004, 02:06 AM
  3. Automotive Grade RCA Cables
    By King_Aero in forum General Hardware Discussion
    Last Post: 03-10-2004, 12:37 AM
  4. RCA Cables How To
    By owenjh in forum General Hardware Discussion
    Last Post: 02-01-2004, 08:06 AM
  5. Where can I find good cheap RCA cables?
    By dudah85 in forum General Hardware Discussion
    Last Post: 09-26-2001, 04:49 PM
