help help. how can i ground my stock deck and my carputer together. is this the right way/solution to go?
im using my stock head unit/deck... (honda accord 2003) which is grounded somewhere, i dont know where...
my carputer is also grounded. i only have one ground to my ITPS. so that should be fine.
i have a ground loop, and to fix this i should ground the stock deck and the carputer at the same spot. RIGHT????
how do i do this??
Your not going to get many answers at 3:00AM - 7:00AM.. Someone will help you out though..
I do had / have alternator noise. It first was when I just had my carputer and I ended up buying a ground loop isolator from Walmart ($12). That fixed it... Now that I've installed an amp it's back...
Current Vehicle: 2007 Dodge Nitro
Second Vehicle: Sold it :( 2005 Dodge Ram 1500 Quad Cab
First Vehicle: 2003 Ford Ranger
Try grounding your audio to the headunit chassis
Originally Posted by Matthew230
hehe. i remember you telling me to ground my audio before..
but i dont know how since my rca cable doesnt have grounding wire with it
the only ground i have is for my whole carputer... should i ground the whole thing to the headunit chasis?
No.Originally Posted by chicochu
Run a wire from the very base of your headphone jack. (I you look at a heaphone jack there are 3 seperate metal parts. The top two are left and right audio, the one at the base is the ground. Run this to the HU audio ground or to the HU Chassis.
If you can't work that, then get RCA's with ground wires on.
