Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: Hi all.. look.. i have a board, HD, memory LCD 4x20 and all what i have to do.?
    Dec 2004
    Dominican Republic
    hi all.. i have all that i think i need to build an mp3 player for my car my car is a Honda Civic hactchback 1991 and i have
    1. board from a compaq computer
    2.intel pentium 166mhz MMX
    3. 64MB ram
    4.HD 650 to 40Gb whatever
    5.LCD display 4x20 samsung
    tell me what i have to do for make this posible? and sorry my english is not good the reason is that im from dominican republic if you speak spanish no problem for me thanks..
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    First question: Are you going to run Linux or a Unix variant? 64mb of RAM is not enough to run Windows. Also a 166mhz PC might decode mp3's if it wasn't running Linux. Otherwise, it would be dicey.
    I'm not sure what kind of display the 4X20 is, but it sounds like a serial LCD display. So to make the computer work, you'll need:
    If you only want to play mp3's, buy an iPod new for $299, used for less. Otherwise, you're looking at:
    1. Power supply. An Opus runs $160.
    2. A screen. If you go cheap, you might get one for $150 or maybe a bit less.
    3. A keyboard. $20 bucks on sale?
    You'd also need some way to get the songs on the computer, either using an ethernet cable or wireless card or USB device. The motherboard you described may not have provisions for that.
    I realize you probably already have the stuff you listed on hand and so it was free, but unless you are a fairly sophisticated computer user, it sounds like it would be very difficult to get it to work.
    Want to:
    Variable Bitrate nzKAOSnz's Avatar
    Aug 2003
    Christchurch - New Zealand
    Bugbyte - hate to differ - but thats close to all i got so far
    de4mon - for that list of equipment - look back through the really old posts in terms of the display.
    what are you going to do for input?
    power?
    Im running a 400Mhz (i think), 3gb hdd, 64mb ram, win98, 2x16 charater display , creative serial IR remote, morex 60w psu
    If you only want to run mp3's at the moment (as i am) - 64mb ram is heaps.
    So i got win98, running winamp with a few plugins for the display, and girder to run the remote (as the creative remote is weird and isnt recognised by the lcd program)
    Dec 2004
    Dominican Republic
    Quote Originally Posted by nzKAOSnz
    power?
    yeah thats all that i need play mp3 for now becouse that's all that i have to make it posible an mp3 player in my car.. and win98 runs nice with this config i can get more ram easy and harddrive... i want to know: with all that i have i can make an mp3 player? and forget the psu...
    Constant Bitrate kalito's Avatar
    Nov 2003
    ny
    start by asking yourself how much money u have to spent on it? cuanto cuarto va a gasta en la vaina etá?
    is all your set up already running or you just have all the stuff laying around,?
    1 a power sourse ( an inverter is cheaper) connect everything as a regular computer,
    2 make sure there is nothing loose or anything that will short out
    3 get a mp3 decoder (like winamp lite)
    4 a key pad to control your software
    5 smoth driving( don't want to mess up your hard drive
    6,7,8 un buen coro pa divertilte.
    Dec 2004
    Dominican Republic
    Quote Originally Posted by kalito
    Jejeje i have money to make it and yeah i have 1 power inverter for car and a regular power supply (es como dije lo hare primero con lo que ya tengo) is how im say i'll try to make it with all that i have. .. im just want to know where i can connect the display and control or if anyone have a plan ... :S... thanks..
    Y si es como te explique tengo todo aqui solo que necesito saber que hacer o mas bien por donde comenzar a trabajar ya que tengo todo para la PC es facil para mi yo vendo equipos de computadoras solo que tengo eso ahi y no tengo porque usar una maquina mas fuerte para comensar..
    Variable Bitrate darkhalo's Avatar
    Puerto Rico
    lo mejor que podes hacer es usar tu inverter. si necesitas ayuda mandame un email.. creo que soy el unico en Puert Rico con un carputer.. bueno yo y mis clientes jajaj.. suerte brother.
    Carputer: 2.8Ghz P4, 512 RAM, 120gb HDD, WIFI, TV tuner, CDRW/DVDROM, Slot load DVD in front.
    Screen: Lilliput 7" touchscreen (Custom made Carbon Fiber Screen Enclosure)
    S2000 Carputer
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    I KNEW as soon as I wrote that, someone would turn up with a system that was similar!
    Question: without a screen, how does it work? Do you set it up with a CRT and then run it headless? How do you control it? What is girder?
    How much music do you get on there with 3gig total?
    Want to:
    Maximum Bitrate Yuriy's Avatar
    Jun 2004
    Seattle
    Quote Originally Posted by Bugbyte
    I wouldn't be so sure My system runs Windows 98 SE (fully loaded) and it's a Pentium 133 with 16 mb of RAM. Decodes MP3s on the fly using Winamp 5. Loads fast too.
    00 Saturn SL2, boosted @ 8 psi - CarDomain
    Newest install - my quickest ever
    My 2nd carputer - b4 I broke the touchscreen
    My very first carputer - voted the most ghetto
    Aug 2003
    bugbyte -
    hehehe- you should seen me in the testing -
    10-20m extension cord, 19" CRT monitor sitting in rear seats
    Works just fine without a screen.
    kudos for that has to go to markus zehnder tho....
    his LCD thingy here
    Ive just seen that work has some 4x40 displays - with bigger text - (about 3"x6") so i gunna talk to the guys to see if one can fall of the back of a truck somewhere.
    For control - i got this IR remote. Does the job - yet to hack it up and hide it tho. The case doesnt look that bad.
    Got to work on hardwiring in some other forms of input - looking at a redundant cruise control lever on my trademe (EBay) steering wheel.
    Girder - ummmm. basicly - inputs from anything to control anything on your computer, run macro's etc etc etc.
    music - ohhh not as much as i have - the only problem is that with more music - more things to scroll through. Win98 takes ~200-300mg, (i think) so i think theres about 600 odd songs. Enough.
    Im thinking about doing something along the lines of where your lcd is... except i want it to rise vertically, not fold open. (so only a 1"x8" cut).
    Still havent found whats actually under there in my car yet.... on the todo list.
  1. Replies: 6
    Last Post: 07-21-2003, 03:18 PM
  2. WTB or Trade: CrystalFontz or Matrix Orbital 4x20 Char LCD
    By King_Xerxes in forum Classified Archive
    Last Post: 05-22-2002, 11:51 AM
