Results 1 to 10 of 15
Thread: PSU tutorial?
    Dec 2004
    PSU tutorial?
    I don't have any of the parts yet or a car but the idea to work on this project has intrigued me for a bout 2 years. I am in the process of researching and hope to begin in the summer of 05.
    My question is: How do you install the opus power supply? Is there any tutorial that I could use, preferbely with diagrams, and pictures.
    I hope to build one of those small mini pcs that stimps has featured on his car. Any help is appriciated thanks.
    Dec 2004
    Here's a shot of what you may be interested in:
    http://www.opussolutions.com/images/...pplication.jpg
    Dec 2004
    thanks that cleared up some confusion. Now How do I connect the OPUS power supply to the battery in real life. Anyone have a picture of themselves doing that?
    Tainted Love Cris's Avatar
    Romania
    You run a 8AWG wire from the battery to the Opus. It's bassiclly the same as the istallation of an amp, only istead of connectoing the remote line to the HU, you connect it to the ignition of the car. Simple.
    Newbie Botimus's Avatar
    Dec 2004
    stuck in Italy
    Cheers P.Diddy
    Reality is NOT your friend
    Carputer - planning stage:
    Option 1 -> 60% complete
    Option 2 -> dead in the water
    Dec 2004
    York, PA
    Rather then running the Opus to the battery could you run it to the power line that feed the stock HU. Since my stock HU will be replaced with the carputer I was thinking of getting the power from there or does the Opus draw to much.
    Raw Wave rando's Avatar
    Mar 2004
    Redondo Beach, CA
    You could but you shouldn't. The Opus may draw too much current which would result in blown fuses, fires, or just unreliable operation. It's always best to install install a new power circuit when adding accessories rather than tapping existing circuits.
    Romania
    Quote Originally Posted by tsteward
    Listen to Rando. He know what he's talking about. Run an amp wire from the battery with an in line fuse.
    Dec 2004
    York, PA
    Thanks for the info Rando, Looks like I will run a line from the battery and mount the opus under the dash somewhere then run lines from there to the carputer that will sit in my front dash behind the touchscreen.
    Dec 2004
    so if i have a normal computer case can i remove that power supply inside the case and replace it with the opus??
  1. Frequently Asked Questions
    By bgoodman in forum The FAQ Emporium
    Last Post: 05-03-2005, 07:25 PM
  2. Mastero 3.5 12v-12v PSU KIT fs
    By SteveC in forum Classified Archive
    Last Post: 09-28-2004, 12:04 PM
  3. Powering up normal ATX PSU
    By KimaX in forum Power Supplies
    Last Post: 09-28-2004, 01:08 AM
  4. hooking up my arise PSU....?
    By jusatry in forum General Hardware Discussion
    Last Post: 03-13-2004, 08:53 PM
  5. What to look for in a PSU some info for you
    By cproaudio in forum Power Supplies
    Last Post: 04-04-2003, 02:07 AM
