Results 11 to 20 of 27
Thread: HD Partitions
  1. #11
    Newbie Draxin's Avatar
    Nov 2004
    Tujunga, Cali
    from what i was taught in school the swap file should be 1.5 times the size of your physical memory for best proformence. but like i said thats what i was taught and there have been many times i have had to correct a teacher. (wow thats sounds so self important)
  2. #12
    Dec 2004
    Wichita Falls, Texas
    Yup thats totally true,....at about the time Windows95 was the dominate operating system. When we were running only 64MB of ram.
    But then again, people could argue this issue forever...has just about as much controversy as the everlasting Intel/AMD issue.
  3. #13
    Dec 2004
    I know of some companies that do backups on a "hidden" partition. Its not a backup for data(always use another device for data) but a backup for the OS and Apps. Right after a PC is set up for its use with all the apps it will be and put the ghost on a "hidden" partition. In the event there is any problem not HD related the ghost can be restored. Its generally faster to do a disk to disk transfer, plus your not bogging down the network or server.
    From personal experience I know some of the installs for some workstations can be 7 hours long. Its much faster to restore a ghost.
  4. #14
    Nov 2004
    Netherlands
    Quote Originally Posted by sevise
    I have made a ghost from my C: (Windows XP setup) on a CDR. I'm currently still in progress, at the moment the ghost file is only 300 Mb in size
    I used XPLite to get rid of all the unneeded **** from windows XP like Outlook Express, games, dll cache, help files and so on.
    I also disabled hibernation (saves me 256Mb file), and disabled system restore, and set temp.inet files to 0...
    My system runs rather fast now, booting in like 30sec, and when i'm on the desktop, only 60Mb ram in use
    Need to install my car-related apps still, but I hope I can fit my ghost on CD (using high-compression)
  5. #15
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    I partition my drive in 3.
    1 OS
    2. DATA
    3. Backup image (ie Ghost the base OS and one with all apps installed + Drivers)
    3 is fat32 so I can ghost back the system should it get corrupted or just need cleaning out. the other two are NTFS.
    However then new system wen it goes in will have two drives.
    one for OS and one for data.
    BTW it is recommended that the swap file be placed on a seperate disk to the system disk if more than one disk is installed. ALthough as the second disk will hold all the MP3's and DIVX's it might not be a goos idea, will have to look into that.
  6. #16
    Jul 2004
    Ohio
    I always suggest ~10GB for windows drive. You can do lower, around ~5-6 works.
    Here's my setup:
    C: Windows (10GB) HDD1
    D: Apps (40GB) HDD2
    E: Games (40GB) HDD2
    F: Music (70GB) HDD1
    Somehow when I partitioned the one it rearranged them like that. I've had issues with windows (Damn you WinME) and it's always nice to keep minimal info in the windows partition. I've done wipes of windows and been back up and running within 2 hours.
    Also, in my Apps folder (since I doubt I'll ever fill it to capacity) I have all the updated install files of all the programs I download. That way, if I ever need to reinstall them they're right at hand.
  7. #17
    Nov 2004
    Quote Originally Posted by DJSmiley
    Turning off hybernation? Windows running faster? 30 sec boot? Man, I kept my hibernation on and on resume it takes ~10 secs with 600 MHZ CPU. I used WINXP pro turned everything off that I could think of.
    That is still a pretty good time for that much RAM I suppose, still depends on CPU speed, but it would be faster from hybernation.
  8. #18
    Jun 2004
    AZ
    Will windows slow down if i am using seperate partitions? Does it take longer to read a video file from partition D if my system or program app is on Partition C? I get this idea because when I install the game emulator MAME, they always say put the directory in the C: directory to run faster (which it does). Thoughts?
  9. #19
    Low Bitrate Shotty's Avatar
    Jan 2005
    Brisbane, Australia
    If you have one hard drive. Just make two partitions.
    Setup your "my documents" folder and your favourites etc. to automatically save into the second partition.
    Have windows installed on the first paritition (along with swap file), that way you can re-image the first partition and still keep all of your data alive.
    (all data (music, backups, documents, etc..) are all saved into the second partition)
  10. #20
    Dec 2004
    Quote Originally Posted by jedi7001
    I think thats hogwash, but thats just me.
  1. Problem with ITPS / hibernation and External USB HD
    By veetid in forum Power Supplies
    Last Post: 01-02-2006, 09:35 PM
  2. epia m1000 nehmiah + laptop HD problems
    By chicochu in forum General Hardware Discussion
    Last Post: 07-14-2004, 05:15 PM
  3. Need help with External USB Laptop HD
    By VWTronics in forum General Hardware Discussion
    Last Post: 05-26-2004, 01:58 PM
  4. Why does my HD stops???
    By nl4jy in forum General Hardware Discussion
    Last Post: 02-05-2004, 11:53 AM
  5. Dying HD?
    By MikeHunt79 in forum General Hardware Discussion
    Last Post: 03-07-2002, 10:47 PM
