Results 1 to 6 of 6
Thread: inverter question.... please help..
    Dec 2004
    Im currently putting together a case for my carputer.... now i have 1 question about hooking up the inverter in the car...
    1st run a 8wg wired from battery to inline fuse to inverter...
    ground inverter to chasis ground....
    if this connection is right and when u turn off the car the inverter still running which power the carputer in standby mode. right,,,
    if this happen wouldnt it drain your battery,,,
    any input is greatly be thanx
    Maximum Bitrate dodgetimes2's Avatar
    MI
    Yes, eventually. But if you drive your car daily you'll probably be alright. Also, depends on how much power you computer draws in standby and the capacity of your battery.
    1.6GHz HP e-PC, 768MB RAM, 120GB WD HDD, Slim DVD-ROM, Onboard sound & video, 7" Lilliput, USB GPS Mouse, Audiovox FM Modulator, Vector 400 Watt Power Inverter, Windows XP Pro SP2, iGuidance 2, 15" Samsung LCD for the rear *Carputer not installed*
    It will drain your battery if you leave the PC in standby, but not if you switched it off. If you want automatic shutdown / Startup then you'd have to build something (there are many threads with suggestions), or buy an Opus.
    Aug 2002
    Quote Originally Posted by Matthew230
    My inverter is hooked to a relay. So when the car is off, my inverter is off, correct? No drain on the battery?
    Self proclaimed spoon feeder TruckinMP3's Avatar
    Jun 2002
    Colorado
    Quote Originally Posted by prerunnerv6
    Yes that is correct.
    TruckinMP3
    Read the FAQ!
    Newbie desiz's Avatar
    Jun 2004
    California
    I just put a little rocker-led toggle switch in my ashtray (which closes). that way i know for SURE that the inverter is off when my car is parked....
  1. Inverter Question
    By friedmaster in forum Power Supplies
    Last Post: 11-06-2004, 06:51 PM
  2. Replies: 13
    Last Post: 09-20-2004, 07:01 PM
  3. inverter question
    By johnyeros in forum Power Supplies
    Last Post: 05-21-2004, 03:21 PM
  4. A newbie inverter question
    By Cliff in forum Power Supplies
    Last Post: 03-29-2002, 10:10 PM
  5. LCD inverter question
    By accord in forum LCD/Display
    Last Post: 04-05-2001, 01:33 PM
