Results 1 to 5 of 5
Thread: First Post. Illumination Wire - Backlight?
    Jan 2005
    Ft. Worth, TX
    Cool First Post. Illumination Wire - Backlight?
    First post. I have visited this forum off and on for the past few years, but I ran into a good deal on some hardware and now I am finally able to get to put a computer in my car.
    I am planning on using my stock radio wiring / stock amp. I was wondering if anyone had successfully used the illumination wire from the radio harness to alter the power of the backlight on a xenarc. It would be nice to adjust the backlight via the illumination wire. I believe the backlight is adjustable with the button on the front of it, but I want hte backlight to dim when the parking lights auto-on. Any ideas?
    Edit: I just found this topic in another thread. Sorry, but hello everyone.
    My Village Called 0l33l's Avatar
    Jul 2004
    Berkeley, CA
    Welcome
    Just use gamma control (search for it, its included in the latest version of NaviVoice).
    Jan 2005
    Ft. Worth, TX
    yes, but its not the same. perhaps this is something i will i have to figure out myself. probably will require a simple circuit to actuate the lcd backlight button.
    Maximum Bitrate Skipjacks's Avatar
    Dec 2004
    Baltimore, Maryland
    The backlight would have to be powered by a 12v source within the monitor. (Unless Xenarc went crazy and made things complicated)
    So you could take it off the power supply from the monitor's circuit board and wire it into the dashlight dimmer. At least I'd think that would work.
    Only problem then is that you'd have no backlight at all (bad thing) when the headlights were off.
    Clover Grayscale's Avatar
    May 2004
    Arkansas
    just use a potentiometer on a 12v line and control it seperately...
    CarPC install is starting to come along again...
  1. Where is 2003 Jetta Ignition Wire?
    By weazelb0y in forum Power Supplies
    Last Post: 03-27-2004, 08:28 PM
  2. CAT 5 wire for audio and etc...
    By NovaKane in forum General Hardware Discussion
    Last Post: 03-24-2004, 09:56 AM
  3. LCDs with no backlight? (LCD Projector)
    By Cyanide in forum LCD/Display
    Last Post: 09-24-2002, 12:52 PM
  4. Motherboard POST time
    By Oldschool in forum General Hardware Discussion
    Last Post: 12-19-2001, 07:45 PM
