Results 1 to 8 of 8
Thread: Start my own carpc build (have a few questions).
    Jan 2005
    Orinda, California
    Ok so i want to start a CarPC, i already have components/software set up for it. The 3 things that I am missing, but researched are; lilliput 7in touchscreen lcd, 90watt opus, and a gps thingy. The specs for the computer are: P3 tulalin 500mhz processor, 768mb of ram, 20gig harddrive. Although i do have a serious question, and it decides if i am going to put it in or not. Ok, my clarion MP3/cd player doesnt have aux input (right here!) , but if i could just splice the cables going from the motherboard, would i be able to play music, and at fairly good quality? My car (a saab 1990 9000CD sedan), already has an amp (although i havent a clue where it resides in the car since it is a stock one, if i couldnt splice the cabling, could i possibly get a cheap amp to replace it?
    cheap custom title JC-S60's Avatar
    Mar 2004
    Ghent - Belgium
    Hi, and welcome.
    I don't get what you mean by splicing the cables from the motherboard. If you have onboard sound, you need to get some mini-jack to rca (tulip) cables to connect the sound to an amp.
    A standard amp that is! My Volvo had an amp too, but that was a positive ground one, which kept blowing my fuses when connected to something else then the stock radio.
    You also could get a fm-modulator, but you will lose on soundquality.
    How do you use the stock amp now? Did you connect the line-level outputs of your clarion hu to the amp or is it unused now?
    If you connected your clarion, you will be able to connect the pc the same way, maybe needing some switch to choose between hu and pc.
    My Village Called 0l33l's Avatar
    Jul 2004
    Berkeley, CA
    Quote Originally Posted by 1st time modder
    Sorry, but Intel never made a 500mhz tualatin. The ram is a bit much... too much ram = slow resume from hibernate.
    Jan 2005
    Orinda, California
    Ok what i mean by splicing, is that the dash has 4 rca outputs, right. So all i would do is attach a splitter, so i could have 2 outputs=going to the same speakers. Although i would have to choose between one source or the other, it wouldnt be to hard. I havent looked for the amp yet, but when i got my head unit installed at fry's electronics, it took them a while to install it because they said it was amplified (3 hrs to install!), they had to modify the wiring harness where the head unit is located to allow it to work, taking out my equalizer in the process (damn i loved it), so i am looking into a carpc to take up its space. The processor might be overclocked to 504mhz, but under cpu-z it reads out as a tulain. Weird huh
    Jul 2004
    Berkeley, CA
    Most motherboards can be off by a few Mhz... but if its a Tulain then you're probably running it at the wrong FSB speed!
    Jan 2005
    Orinda, California
    can we disregard the computer specifications here, and concentrate on the serious questions at hand. I looked at a the M1-atx or the carpcpro v2.2, which one do you think would be the best. I liked the functions of the carpcpro, but am unsure of which one to get? should i go for around a 250-350watt inverter seeing as the computer + screen wouldnt take up much power
    Constant Bitrate KennyKen's Avatar
    England
    Quote Originally Posted by 0l33l
    ***Thread Hijack***
    Is this just in the above situation or in general?
    Does anyone know why?
    Cheers
    ps sorry for the Hijacking
    Jul 2004
    Berkeley, CA
    Quote Originally Posted by KennyKen
    ***Thread Hijack***
    Cheers
    In general, the Tutatalin was never available at that speed.
  1. Five stupid newbie questions I had to ask.
    By mpfjr in forum General Hardware Discussion
    Last Post: 01-04-2005, 09:11 PM
  2. Newbie who has a few questions. . .
    By Sillydipstixs18 in forum Newbie
    Last Post: 12-21-2004, 11:30 PM
  3. System Build Questions Power,USB,Etc.
    By bobs987 in forum Power Supplies
    Last Post: 12-08-2004, 05:20 PM
  4. 3 Sound related questions for CarPC
    By nirvanades in forum General Hardware Discussion
    Last Post: 05-31-2004, 09:04 AM
  5. Just A few Questions Before I start buying
    By crazyshaxs in forum General Hardware Discussion
    Last Post: 11-20-2000, 03:16 PM
