You would have to put an additioal in-line fuse on the small bulb wire to protect it. I have a main fuse at the battery. That 1/0 wire goes to a fused distribution block with smaller fuses.Originally Posted by DallasCamaro
Thanks fantomas. U laid out what I was trying to say. Big enough to handle the load, but small enough to protect the wiring. By the way....ALL wires attached to that circuit should technically be sized to handle the fuse. Thus, don't tap in a 20 gauge wire just to run to one little light bulb somewhere. If that lil wire shorts out, it could catch fire before the fuse blows. So, as Fantomas said, the fuse should be large enough to handle your loads, but small enough to protect every wire in the circuit. And, of course, as close to the battery terminal as possible.
2.4 celeron
150 watt OPUS
micro atx
xp pro
tv/radio tuner card
audigy
Dual monitor Radeon
802.11G Mimo
xm pcr
dvd
gps
8" Lilliput touch screen
IGuidance
dual optimas
battery isolator
15" screen
My Truck
A 40 amp fuse would work fine. If you plan on using a 750 watt inverter in the future, I would use 6 gauge wire. There will be no problem in using a larger wire. It's just more $$$.Originally Posted by nsmoller
2.4 celeron
150 watt OPUS
micro atx
xp pro
tv/radio tuner card
audigy
Dual monitor Radeon
802.11G Mimo
xm pcr
dvd
gps
IGuidance
dual optimas
battery isolator
15" screen
My Truck
Yes that is 3000 surge, but for sizing wire and fuses you need to make sure you can accomidate that. Its 1500 watts normal. 20 amps * 120 volts is 2400 watts. But besides that, my inverter has 2 outlets.Originally Posted by fantomas
2.4 celeron
150 watt OPUS
micro atx
xp pro
tv/radio tuner card
audigy
Dual monitor Radeon
802.11G Mimo
xm pcr
dvd
gps
IGuidance
dual optimas
battery isolator
15" screen
My Truck
I have one 130 amp alternator. I dont plan on using that many watts though. I'm only running the computer, stereo and some screens. But I got a good deal on the inverter and it's nice to know that if you ever need it, its there, at least until you kill your battery which would be pretty quick at 275 amps.Originally Posted by DRWeside
2.4 celeron
150 watt OPUS
micro atx
xp pro
tv/radio tuner card
audigy
Dual monitor Radeon
802.11G Mimo
xm pcr
dvd
gps
IGuidance
dual optimas
battery isolator
15" screen
My Truck
2.4 celeron
150 watt OPUS
micro atx
xp pro
tv/radio tuner card
audigy
Dual monitor Radeon
802.11G Mimo
xm pcr
dvd
gps
IGuidance
dual optimas
battery isolator
15" screen
My Truck
to keep the convo running
6AWG fused w/40A fuse
to
Distribution block to DSSC and power line on amps?
DSSC to monitor, remote on amps, usb hub?
[4Runna]
next - wifi
DSSC? Is that a voltage regulator? Not sure what that is but I think you got the right idea.
2.4 celeron
150 watt OPUS
micro atx
xp pro
tv/radio tuner card
audigy
Dual monitor Radeon
802.11G Mimo
xm pcr
dvd
gps
IGuidance
dual optimas
battery isolator
15" screen
My Truck
