Hey brandon, I've got a 2000 Camaro, and right now I'm in the process of building a system to put your AC controls into the carputer. It will basically be a driver board plugged into a serial or parallel port, which will control your AC system, I'm just finishing up the hardware part of it, and hoping I can talk some of these front-end designers into adding it to their software. For now, my AC control is in the glovebox. If you take the AC control out, you will find 3 things basically. There is a wiring harness plug in.....this controls fan speed, ac request signal, control illumination, and rear defroster control, then there is a cable.....this cable runs from your temperature knob to the blend door in your evaporator unit. the cable is long enough to be rerouted. I moved mine without disconnecting this cable, but if you need to, e-mail me for directions. It is easiest to disconnect from the blend door, not the control unit. Then ypu will find vacuum tubes. 7 of em I think. they plug into the mode knob, through a vacuum plug. these are simply tubes which carry a vacuum, the vacuum is applied to door actuators when you turn the knob, controlling where the air blows. If you unplug the vacuum harness, you should be able to move the plug over to the glove box area and plug it back in. Then all you need to do is lengthen all the wires in the elecrical harness going to the unit.
If you are trying to relocate it farther <the center console, i thought about that, but mine's only temporary> you're limited by the blend door control cable. But there are ways around that if you need to, lemme know
-Rob
LinkBack URL
About LinkBacks
