Results 1 to 2 of 2
Thread: would this ps work for car installation?
    Jan 2005
    Question would this pc work for car installation?
    hi from Sergio
    i am new to this site and need some help
    can you tell me if this computer is a good one to use in my car sice so many
    are experts at this and used many different ones how about this one
    am also considering buying the units for resale so what do you think?
    ALSO WILL IT SUPPORT A 7 INCH TOOCH SCREEN VGA AND HOW GOOD IS
    THE SOUND ON THIS BOARD
    thank you
    Product Name: CAR PC USA
    CPU VIA Eden 10000MHz (BGA)
    CPU Voltage / FSB 1.05V / 133MHz
    Power Management APM 1.2
    Chipset VIA CLE266 - North bridge:VT8623* 548 PIN BGA; South bridge:VT8235
    VGA CLE266 Intergrated AGP8X, Shared System Memory 64MB Max(one channel LVDS interface)
    BIOS Whizpro BIOS* 4 Mb with etBIOS
    LAN Realtek 8139C, 10 Base-T /100 Base-TX Protocol (wake on LAN)
    Sound Realek ALC650 on board controller + AC97 Codec (Line-out, Line-in, Mic, S/PDIF out),On board Pin header Type
    Memory type 1xDDR memory module,2.5V PC133/DDR 266 (without ECC function),MAX. 1GB
    LPC I/O VT1211: COM1, COM2
    KB/Mouse Controller VT1211 Built-in
    Card-bus(PCMCIA) TI1410 PCI single chip Card-bus controller support 1 channel
    Local bus IDE VT8235 build-in, IDE1-40 pin box header(Ultra DMA 33/66/100/133), IDE2-40 pin box header
    Power Connector DC-in 19-24v /7.5A-8A ( DC TO DC Module 12V/5V/3.3v)
    USB 2.0 6 ports; 4x D-TYPE connectot and 2x pin header; transfer rate up to 480Mb/S.
    IEEE 1394 2 ports ; VIA VT6307S IEEE 1394 Firewire
    IrDA (Infrared) Included in south bridge, pin-header
    I2C Included in south bridge, pin-header
    Onboard Connector (Front-Side) DC-JACK (DC-OUT ),19V-24V
    Onboard Connector (Rear-Side) 1x RJ45; 4x USB connectors (D-type); 1x PCMCIA Connector; DC-JACK (DC-IN )
    Onboard Slot 1x PCI slot
    Docking Pin-Header 2x additional USB 2.0 ports in Pin-Header(2x5x1)
    2x 1394 ports in Pin-Header(2x5x2)
    Audio connectors in Pin-Header(Mic, Line Out,Line In)(2x4x1)
    CD Audio-in Pin header(1x4x1)
    AUX-IN Pin header (1x4x1)
    FIR Pin-Header (1x5x1)
    CPU FAN, Sys FAN (1x3x2) -- Have thermal control
    1x I2C connector in Pin-Header (1x6x1)
    1x LVDS connector (20 pin)
    1x Inverter connector
    2x Serial port Pin-Header(2x5x2)
    S/PDIF out
    2x IDE Pin-Box Header (2x20x2)
    2x IDE Power Pin-Header (1x4x2)
    PS2 K/B,Mouse Header(2x3x1)
    Pin-Header for PWR B/T,PWR LED,HDD LED (2x4x1)
    1x VGA Pin-Header (2x6x1)
    Dimension H 50mm X D 200mm X W 145mm - With aluminum Thermal-boxed solution
    _
    Mar 2004
    Little Elm, Texas
    looks like it's just your typical mini-itx board, no?
    yes, it will work, as a quick search would have revealed to you being that like half of the people on here use MINI-itx boards
    yes, the vga touch will work, that's not exactly a question that I have heard before, guess it's just something that everyone assumes.....
    and sound quality - again....SEARCH!!!! there are like a bagillion threads on sound quality......it all depends on what you will be listening to your music through.....what kind of system, sound card, amps, etc.....
    again....stick around for a while and read up a bit before asking questions.....most of the questions have been answered and have an entire thread going dedicated to that very question and will answer it beyond what you could have ever wanted!
    welcome!
    Jan Bennett
  1. Cant' get Lilliput to work
    By audi04a4 in forum LCD/Display
    Last Post: 08-25-2004, 12:25 PM
  2. Nissan 100 NX (1600) part II (getting it all to work
    By videodok in forum Show off your project
    Last Post: 05-21-2004, 05:32 AM
  3. how to get milkdrop visualizations to work?
    By DSM97RS in forum MediaCar
    Last Post: 04-01-2004, 10:22 PM
  4. DVD and CD burner dont work above win 98
    By Mikesz in forum General Hardware Discussion
    Last Post: 02-09-2002, 08:56 PM
  5. 250W PS and a 300W Inverter
    By kane2g in forum General Hardware Discussion
    Last Post: 11-22-2000, 01:08 AM
