By "ignition" you mean "accessory"? If that is the case then the answer is yes. The accessory wire should already be fused at the fuse box. If you want to add another fuse, use a low amp one, 5 Amps should be plenty. I don't have an extra fuse on mine and works fine.Originally Posted by forevertheuni
LinkBack URL
About LinkBacks
