Results 1 to 10 of 14
Thread: Turn on Laptop via Ignition?
    Jan 2005
    Hi. I have a hp pavilion ze4900 running xp that i want to put into a bmw 325i.
    My question is:
    How can I make it so that when I start the ignition, the laptop turns on.
    My laptop bios doesn't have a wake-on-power type option.
    Sep 2003
    Austin, TX
    You might be able to just put it to sleep/hibernate. Then come back to it and it comes on instantly.
    Jan 2005
    I would like to get it in and out of hibernate automatically as well.
    Constant Bitrate Prindle19's Avatar
    Dec 2004
    Jersey/Virginia Tech
    check to see if you can set up your cigarete lighter to work with your ignition. usually this is a fuse setting. it may be possible to set it up so that when you turn off the car, the cigarette adapter becomes unpowered. in the power management of the latop, you would then set it up so that when it looses the plugged in power source, that it will automatically shut down (or preferably hibernate) problem that is bigger is going to be your start up. youd still need to push the power button to wake up from hibernation after you get in teh car and give the port power.
    Jan 2005
    All of the 12V sources in my car stay on regardless of the ignition status.
    I know that the ECU has a trigger wire, but I don't know how I can use that to startup the laptop.
    Are there software solutions?
    Jan 2005
    if it is going to be a permanent install of the laptop then you could hack the power switch and but it on a relat or a external button
    MySQL Error Scouse Monkey's Avatar
    Mar 2004
    Bristol
    phita there are loads of threads on this and one main one with a wiring diagram.
    Jan 2005
    Quote Originally Posted by Scouse Monkey
    I don't know what keywords to search for.
    Laptop, remote on, ignition?
    Mar 2004
    Bristol
    The key words you list would be good but how about "startup" as well here is a good thread....
    Remote laptop startup
    Jan 2005
    Thanks scouse, that opened up many new options.
    If the docking station can power up the laptop, thatmeans certain pins that connect the dockingstation to the laptop are the powerup ones.
    How do I test that, without buying a docking station?
  1. Remote laptop startup
    By ambush in forum Laptops, Netbooks, Tablets, UMPCs, etc.
    Last Post: 11-24-2008, 03:28 AM
  2. Stupid Xenarc! It won't turn on when laptop is on or display correct!!
    By PDiddy in forum General Hardware Discussion
    Last Post: 01-17-2005, 08:53 PM
  3. Laptop remote on/off issue -- SOLVED: s2000 carputer
    By skybolt in forum General Hardware Discussion
    Last Post: 09-20-2004, 11:52 PM
  4. Replies: 3
    Last Post: 08-20-2004, 09:42 AM
  5. Anyone figure out how to turn on laptop?
    By RTman in forum General Hardware Discussion
    Last Post: 08-10-2000, 09:19 AM
