If you want to connect your carputer and laptop network ports together without using a hub then you will have to use a 'cross-over' network lead instead of a straight through cable. You should be able to buy this or if you want to make it yourself have a look here for the wiring diagram.
As for the audio i'll have to leave that for somebody else who owns one of those m'boards.
LinkBack URL
About LinkBacks
