Results 1 to 7 of 7
Thread: Dumb USB DVD question
    Low Bitrate Sir Lancerlot's Avatar
    Oct 2004
    Irvine, CA
    Ok. I've been told there are no dumb questions so here I go. I am looking to install my comp in the trunk and locate the CDRW/DVD drive up front. looking at USB powered drives. I need to know if the only thing I need is to run 2 wires. one USB for data and the other USB for the power? is the Audio sent over the USB? or do I need to run an audio cable to the sound card like my internal CD drive I already have in my comp? hope thats not too dumb a question.
    Maximum Bitrate Vchat20's Avatar
    Jan 2005
    Warren, Ohio, USA
    most likely if its usb powered, the power and data will run on the same cable. and yes, the audio is sent over usb as well.
    FLAC IntellaWorks's Avatar
    Jun 2004
    NH
    Quote Originally Posted by Vchat20
    On the contrary, they typically need two USB cables. (Mine does anyhow) Here's the kicker, they gave me a power cable which is two feet long and a USB cable which is 6ft. I guess it says some computers can power it without the power cable and some can't, my VIA MII 10000 canot power it without the second cable, I'd love to tell you the type of USB dvd player I have but I'm not at home and I can't remember off the top of my head.
    Audio gets played over the USB though.
    Progress [I will seriously never be done!]
    Via EPIA MII
    512MB RAM
    OEM GPS (embedded)
    nLite WinXP pro on
    1GB Extreme III CF card
    Carnetix 1260 startup/ DC-DC regulator
    Software: Still, re-Writing my existing front end in .Net
    Constant Bitrate strohmrs's Avatar
    Jun 2004
    Idaho
    Some drives require a second USB cable. You could run both or run one and add a powered hub to the end of it. That would give you a second port for the power and at least two additional ones for other USB devices up front.
    The audio will be sent digitally through the USB cable as long as the drive supports it (most do) and you have the drive setup that way in the device properties.
    Rick S.
    XP Pro SP2, Soyo P4RC350 MB, Nvidia FX5200, 320W PS, Inverter & uSDC20D, 2.4GHz CeleronD320, 512MB DDR, 30GB 3.5", Pioneer 106s Slot DVD, Linksys WMP54G WiFi, Lilliput 7" & 4" TFT LCD, Zippy EL610 Keyboard, Touchpad, Garmin GPS V
    Constant Bitrate Maukio's Avatar
    Jul 2004
    Oklahoma
    You could just extend a 5 volt rail off your PSU to the DVD drive and hack open the power usb cable and splice em together. That's what I did and it works perfectly. So you'd have two wires going up - usb for data and probably 18awg speakerwire for the 5 volt & ground line off your PSU up to the spliced power USB cord. I can post a pic if I'm not being clear.
    '99 Accord LX
    Pics of CarPC Setup
    Jan 2005
    Please, post a pic.
    Oct 2004
    Irvine, CA
    Hey cool..thanks for all the posts. Makes my decisions a lot easier now
  1. Problem with ITPS / hibernation and External USB HD
    By veetid in forum Power Supplies
    Last Post: 01-02-2006, 09:35 PM
  2. another USB slot dvd thread!
    By tdevil in forum Newbie
    Last Post: 08-21-2004, 01:17 PM
  3. DVD drive question
    By Pokey in forum Newbie
    Last Post: 05-11-2004, 05:26 PM
  4. Replies: 4
    Last Post: 04-06-2004, 10:52 AM
  5. USB DVD + Radio Tuner + OEM GPS
    By gguy in forum General Hardware Discussion
    Last Post: 02-13-2001, 12:43 PM
