to some of the people concerned about the dual CC in the dash- if it also has the in-dash CD changer then it is nothing like the single CC controls (that has a temp setting and a fan setting) or dual CC controls without a CD changer (which does not use the OSD of the radio?)
The dual CC has a temperature setting that integrates into the stock CD changer head unit and displays the temperature settings on the stock unit's screen- so I can set the driver side for 65 degrees and the passenger can set the dial to 72 degrees. Hell- it is even possible that the dual CC controls are integrated into the radio head unit- but I have not taken it apart myself.
There is no stop/start point on these dials- you keep turning it left, the display will indicate 'lo' under 60 degrees- you keep turning it right, the display will indicate 'hi' over something like 88 degrees- so without the display, you really have no indicator of if the setting is on high or lo or somewhere in-between.
i found this out when the backlight in my head unit died (an issue with some 03 accords)- i could not see where the temp was so I had to keep screwing with it until it got hot/cold enough... you could somewhat see the numers in direct sunlight, but at night it was black. luckily I got the 5 yr/100k warranty so it was a free swap \...
the dual climate control seemed pretty cool when I was first lookign at the car as I like cold-*** temperatures (usually on 65 in the summer- 70 in the winter) and my passengers usually do not. in retrospect, it is a pain-in-the-*** for trying to get a LCD display installed as neither upper or lower locations are optimal for a motorized display: I do not know of a pre-fab upper cd changer+dual climate control panel and a lower pre-fab install will hit/block the radio buttons and A/C contols or the shift handle).
I will proably either hack the lower 'pocket' and install a fixed 7" LCD or learn about the fun of fiberglass and fabricate something so I can keep the pocket in case i want to go back to stock when I sell the unit.
I think someone makes a 2 DIN motorized LCD- I need to find some more info one that- does anyone have one installed?
Something like this is what I will probably end up doing: http://www.kuo.freakstylehosting.com/car.html
I would like something like this, but you can see how the screen is in the way: http://www.sounddomain.com/ride/690811/4
This is the upper panel for a dual climate control system (which looks like ***) but without the in-dash CD changer: http://www.autotoys.com/x/catalog/HO...AL_p_5065.html
...and this is the lower kit: http://www.autotoys.com/x/catalog/HO...WER_p_694.html
Oh, and if you haven't found the 2003 Honda thread on this forum, it is pretty helpful: 2003 2004 2005 Honda Accord CarPC
LinkBack URL
About LinkBacks
I'll take them asap, although you'll see a gapping hole where the flipout 7" VGA screen will be.
