Here is my xenarc in the lower cubby. And my pc goes into the AUX n on the factory radio thru my Car2PC adapter.
10 acura TL tech
10 BMW S1000RR
I have a quick Q I installed jbl gto 6by9s with the stock stereo, (bit of a waste, low power amp), if I installed an amp and say some infinity kappa 6.5s in the front would I get some performance, the jbls sounded awesome before in my old car with an after market deck and no amp
Does anyone have pictures of the back of the top mount metra kit?
I am thinking about having doing something like it, but wanted room for a 7in widescreen. I would like to use the lower part and relocate the top controls and buttons.
Thats pretty ambitious to relocate the controls. I have dual air so it wasnt really an option cause all my dual a/c is basically part of the OEM radio.
And the metra kit just looks odd to me.
10 acura TL tech
10 BMW S1000RR
I had to go through the door because i was unable to find a place to put it through the firewall. i put on some cable covering so its very unnoticable. as far as the panels to run it back, i just pryed up the running boards, and the wall panels a little, and ran the cable under them, was quick, i had power to the trunk in like half an hour.
03 Accord coupe
2.4 ghz media pc, DSSC, 200w Inverter, xenarc 7inch ts.
Parts: 75%
Install: 75%
Yea i used th main factory grommet and pushed my 4G wire thru there. And yes the back seat has 2 like PULL tabs that will release the bottom cushion upwards.
10 acura TL tech
10 BMW S1000RR
