Page 1 of 17 1234567891011 ... LastLast
Results 1 to 10 of 162
Thread: 2003 2004 2005 Honda Accord CarPC
    Feb 2005
    2003, 2004, and 2005 Honda Accord Owners: This is our refuge.
    Congratulations! By utilizing the function of this website, you have made it to a refuge for newer-model Accord owners. The flamers (with good reason), whom you may have encountered already, would be proud.
    With the calamitous dash-orientation that we 2003, 2004, and 2005 Honda Accord buyers have been afflicted, I thought it would be helpful for our CarPC aspirations to have a thread dedicated to questions, answers, problems, successes, links, and as many pictures as possible related to the installation of CarPC's in the aforementioned Accords.
    Here are some links to start:
    CarPC's in 2004 Honda Accords
    2004 Honda Accord CarPC Thread
    http://www.soundongames.com/car/carputer/#
    http://www.sounddomain.com/id/prttyboythugg
    Aftermarket Deck Installs
    Metra Turbo 2 Dash Kit:
    Top mounts:
    http://www.sounddomain.com/memberpage/575049/3
    http://www.sounddomain.com/memberpage/449694/2
    http://www.sounddomain.com/memberpage/647693/16
    Bottom mounts:
    http://www.sounddomain.com/memberpage/393094/2
    http://www.sounddomain.com/memberpage/632570/2
    http://www.sounddomain.com/memberpage/608226/2
    http://www.sounddomain.com/memberpage/697869
    http://www.sounddomain.com/memberpage/562870
    http://www.sounddomain.com/memberpage/690811/4
    Removal instructions:
    http://www.cardomain.com/memberpage/561772/3
    2003-2005 Honda Accord Wiring Colors and Notes
    http://www.designtech-intl.com/Conte...l?modelID=1614
    CarPC Progress
    Research - 3%
    Constant Bitrate fallnangel's Avatar
    Richmond va
    haha ..awesome man thanx for the links.
    ..and dont back out just because u think its too crazi , i hate pussies
    -outdidya
    epia m1000,256mb ddr,7"lilli,120gb hdd, Ati remote wonder,400watt inverter,350psu all under xp pro-installed
    Newbie calvincbr's Avatar
    Nov 2004
    San Luis Obispo, CA
    Any new installs for 03 -05 accords
    Anyone try customizing a lower mount bezel for the accord?
    Variable Bitrate Saab9-5's Avatar
    Mar 2005
    Ponta Delgada, Azores
    You guys won't want to miss the progress on this late model Accord install.
    03-05 Accord 7" Mold
    May 2004
    Quote Originally Posted by calvincbr
    yep
    done
    Mar 2005
    those upper dash mount kits look aweful. just my personal opinion..
    lower mount kits would be better IMHO if you could retain the OEM door over that area. that would keep it out of prying eyes.
    98exl and I are going to ~try~ and crack the "can't remove the HU" problem. factory electrical manuals are coming.... If we can't crack it, we'll probably just extend the wires long enough to hide the OEM HU somewhere out of the dash, or strip the HU apart down to just the board, and chuck the mechanicals.
    Constant Bitrate 98EXL's Avatar
    Mar 2005
    Maryland, USA
    Quote Originally Posted by jweller
    Can I get a HELL YEAH!
    Down with factory HU, it's "teh suck"
    I think that OEM DVD player shell from the navi is perfect hiding spot for a mini-itx mobo.....and it will continue with the stealth OEM install theme. Hopefully more work will continue on the screen tonight....so much sanding to do. Maybe more sanding, and a primer coat will be put on tonight
    Molded Screen:
    [++++++----] 60%
    DVD & Rest of audio:
    [++++++----] 60%
    2004 Accord Coupe, Satin Silver K24 5 Speed powa!
    7" Lilliput Screen, non touch with lots of Bondo
    NTB DVD player or put XBOX in car
    My 04 Accord Picture Thread
    Feb 2005
    HELL YEAH!
    IMHO great work so far 98EXL! I'm eager to see the finished product. Thanks for the link.
    Mar 2005
    Maryland, USA
    god I hate sanding.....grrrrrrrrrrr
    Molded Screen:
    [++++++----] 60%
    [++++++----] 60%
    Jan 2006
    looks like im posting in the right thread I have a 2003 Accord, and I really want to start putting in a carputer, but i have little understanding and alot of questions behind the wiring of the 03 accord. From what I've gathered, I need a 12v+(unswitched) connection from the battery, an ignition(switched) connection, and a ground. right? Are these wires provided, and are they visible once i rip out the storage tray (under the radio) or the ignition harness? Or do I need to buy reels of 10 or 12 guage wire and wire everything myself? Could I wire everything from the 12v adapter next to the coin holder, or should i wire from the source (battery/ignition)?
    These are the basics of what id be installing
    Xenarc 700TSV, M10000, M1-ATX,
    Would I need a ground loop isolator if i wanted to connect the audio to the Aux connection using a SNHOND3?
    Would I power the monitor the same way as the M1-ATX (battery/ign/ground)? Do I need a power regulator, and/or an ITPS? or are these integrated into the M1-ATX? If i need wire, relays, fuses, etc, or a kit for all this, can anyone kindly provide links to the right products, and/or wiring diagrams.
    if anyone can help me with these questions, I'd really appreciate it.
    books i will be getting soon , Car PC Hacks and Build Your Own Car PC
    Thanks again
  1. 2003 Honda Accord Ex V6 puter
    By Google in forum Show off your project
    Last Post: 09-05-2008, 12:41 AM
  2. need tips for 2004 accord sedan install
    By keghead in forum General MP3Car Discussion
    Last Post: 07-07-2006, 05:48 PM
  3. 95 Honda Accord In-Dash Install
    By Gewehrschuss in forum Show off your project
    Last Post: 01-24-2005, 12:52 AM
  4. Full install Honda accord aerodeck
    By ColonelB24 in forum Show off your project
    Last Post: 09-08-2004, 11:21 AM
  5. Replies: 5
    Last Post: 05-12-2004, 10:42 AM
