Results 1 to 8 of 8
Thread: will my carputer audio work threw my alpine?
    Feb 2005
    Question will my carputer audio work threw my alpine?
    Going to install carputer very soon but i still have one situation not figured out yet?! I have an alpine cd deck(CDA-9811) that i want to keep for AM/FM and as a way to control the audio coming from the carputer to the amps and speakers. It has an input for a changer control so is there a way to get the audio out put jack on the back of the built in sound board to work threw the cd deck? If any one has any ideas of how to do this or knows of a better way that will not be way to expensive please help me out.
    PS I love this site, lots of good info and helpfull people!
    what im looking to do for the hook up
    carputer-----alpine deck------amps----speakers
    Takes it in the Rear kevinlekiller's Avatar
    Dec 1969
    Where the penguins and polar bears live.
    Hi I used to have the same problem has you, I resolved it by getting a new head unit with Line-In. But this isnt what you want. I used to have a similar alpine player, on the back of your deck there is a female adapter.
    The female adapter is called : M-BUS.
    Anyways on the internet you can get a M-Bus to Rca Connecter. On one end its the M-Bus Male connector and on the other end its 2 rca connectors.
    You can look it up on google they'r between 10 and 20 dollars.
    Here is a site with the cable (you can find a better deal, I just took the first site I saw so you can see what it looks like).
    http://www.sonicelectronix.com/item_2082.html
    Low Bitrate CoCa's Avatar
    Dec 2003
    Rockford, IL
    Acutally, since the head unit is designated CDA, it uses Ai-NET protocal, requiring an Ai-net adapter, NOT an M-BUS. You want this http://www.sonicelectronix.com/item_2081.html instead. However, if I was you I'd wait and see how the computer to Ai-NEt interface that someone on here is working on pans out.
    Dec 1969
    Oops, sorry I thought it was tda... not cda
    Feb 2005
    thanks guys. ill look into the adapter listed above. About the project that may pan out do you have a link to it and what is the finalization of it going to be. I would like to get every thing in the car and hooked up in the next few weeks
    *edite* just looked in the manual and man you guys are good. yes its a Ai-NET cable. Ill call around localy to see if any one has them if not ill buy it from the link above.
    Next question if any one has done this before does it sound just as good as cd in the deck unit??
    _
    Mar 2004
    Little Elm, Texas
    it all depends on the sound card/on board audio that you use.....onboard audio won't sound as good as a good sound card...but it's all dependent on your audio system in the car
    Jan Bennett
    Feb 2005
    just got off the phone with car toys they have one left.. im off to pick it up and its only $20!! Ill try the sound car thats on my mini itx board and if i dont like it then ill just upgrade i suppose.
    _
    Mar 2004
    Little Elm, Texas
    that's probably your best bet!
    Jan Bennett
  1. Alpine M-Bus Aux Input
    By MatrixPC in forum General Hardware Discussion
    Last Post: 07-05-2010, 12:17 PM
  2. XMDirect Digital Audio Output ?
    By Retsaoc in forum General Hardware Discussion
    Last Post: 10-11-2004, 09:10 PM
  3. How does the audio work here?
    By skaska in forum Newbie
    Last Post: 05-02-2004, 02:24 PM
  4. Replies: 0
    Last Post: 01-06-2003, 02:35 AM
  5. Best way to hook up audio in a new carputer?
    By Fruitloaf in forum General Hardware Discussion
    Last Post: 06-18-2002, 05:31 PM
