Results 1 to 3 of 3
Thread: dvd fullscreen: last obstical
    Constant Bitrate mpfjr's Avatar
    Jun 2004
    Corona, CA
    I am down to my last bug in my system to work out and haven't had much luck. Yes, I have & I have and I even and I am still not finding the right answer for me. Maybe it is because I am so clueless on this and it is an obvious fix I don't know but I could sure use your help.
    I have powerdvd 6 installed as my only dvd decoder codec and I have both centrafuse and frodoplayer installed while I test each one. Both have give me the same dvd playback at fullscreen problem. The problem is that there is a 1/2 inch border around the whole picture. I went into the powerdvd settings and attempted to play around with various settings to try to get it to play full screen 16X9 and I can get it to work there. I have also checked through the settings in WMP 10 and it works fine there too. But when I play a dvd through either frodo or cent the same 1/2 Inch border around the movie is there. I tried using the advanced settings under frodo but that didn't work.
    I am running at 800x480 if that makes a difference on a Xenarc 7" screen using nvidia nforce2 chipset board and powerstrip.
    Low Bitrate cavramair's Avatar
    Aug 2003
    Are you sure that your PowerDVD software supports that resolution. Its an odd resolution to other programs I have seen. It might not like that. Move your resolution to 800x600 and see if that helps.
    -Drew Taylor
    2000 Grand Am GT PC
    See me in my wet t-shirt. stevieg's Avatar
    Aug 2003
    Warwickshire, UK
    If you can't find anything in the Frodoplayer forums, you might be best posting in there and asking... I can't see anything obvious if works fine at that res in WMP/PDVD
    Ford Focus MP3 : Blog Updated 29 January 2009!
    Car PC Status: Complete - Undergoing Software Redevelopment
  1. Slim DVD & IDE to USB - DVD QLTY
    By ZimZimmer in forum Newbie
    Last Post: 01-19-2007, 06:37 PM
  2. DVD_ dvd playback is choppy
    By Squid in forum FP Bug Reports
    Last Post: 12-02-2004, 12:29 AM
  3. Bug Reports
    By frodobaggins in forum FrodoPlayer
    Last Post: 10-16-2004, 01:25 AM
  4. Deal alert: Mobile DVD Player w/5.6-inch Detachable Screen $99+5 shipping
    By mykolJay in forum General Hardware Discussion
    Last Post: 09-27-2004, 01:59 PM
  5. DVD Rips?
    By EBFoxbat in forum Newbie
    Last Post: 07-20-2004, 07:09 AM
