Page 1 of 4 1234 LastLast
Results 1 to 10 of 34
Thread: Need Help With Cold Cathodes
    Constant Bitrate ClubFed11's Avatar
    Killa Cali
    Didn't know where to post this, or even if this is the right site to post this on. But you all seem good with cars, So I was wondering, I have this cold cathode setup for my computer, and we all know that the comp and the car both use 12V, so can i just hardwire into my cig lighter?
    If so, I noticed that there was 2 wires going to it, i am guessing one is ground and the other +12.
    Any guides or help would be great, thx a lot.
    2009 Altima 2.5S CVT Dark Slate
    Nic
    Nic is offline
    FLAC Nic's Avatar
    Oct 2003
    Melbourne, Australia
    if you connect it straight to the car its going to get 14+ volts when the car is running, not to mention voltage spikes and dips when you are starting the car. This *may* blow it up i dont know how resistant they would be to that kind of abuse
    Signature: [==||========] 20% complete
    Killa Cali
    Any way to protect it from getting more then 12?
    Elsewhere
    Quote Originally Posted by ClubFed11
    Regulator.
    How about the Wiki?
    Variable Bitrate Grimey's Avatar
    Feb 2005
    Moody, ME
    Are you trying to wire it in your computer? If so I have cold cathodes in my computer and they just plug into the power supply within' the computer. Why would you need to wire it to your cigarette lighter?
    Gender is Questionable ibrennan's Avatar
    Jun 2004
    Moorestown, NJ
    I have one running off my car's 12v....it works fine for cold cathodes
    2001 Explorer
    Xenarc, Opus 90W, 120 GB HD, Bondo everywhere
    Sold the Explorer...got a 350z
    Constant Bitrate shiltz's Avatar
    Dec 2004
    Massachusetts
    yeah, cold cathodes are just fine being hooked directly up to the car battery, i've had one on my sub box that's been hooked up like that for about 5-6 months now with no problems.
    2005 Dodge Magnum RT, Samsung Galaxy Tab install
    Killa Cali
    And you all have an inverter right?
    You don't just wire it directly to the batterie right?
    And no, I don't have a computer in my car.
    Maximum Bitrate kiltjim's Avatar
    Feb 2004
    PA, USA
    Right. You keep the inverter that comes with the CCFL. You do not wire the tube directly to the battery. You can get away without a regulator. I don't know how long it will last, but trust me, they are a lot more resilient than they let you believe.
    I have been trying to design a CCFL dimmer circuit, and have been treating one of my tubes quite badly. Ramping voltage, DC "sine" waves, intentionally spiking it to about 15 volts, all sorts of horrid things. I have it running under my desk right now, going from about 5 percent brightness to about 90 percent. Its really a cool effect, but it can give you seizures after a while....
    2000 Subaru OBS
    Dell P3 @ 900 Mhz
    7" Lilliput TS w/DigitalWW in-dash mount
    80GB External HD
    I am Zero Bitrate....
    Killa Cali
    lol, thats great.
    So I wire the inverter which is connected to the CC to the batterie?
    Do you think I could just use the cig lighter? I don't really wanna go through the firewall and all that if I don't have too.
  1. harddrives withstanding cold temperatures?
    By Nick DC in forum Newbie
    Last Post: 12-11-2004, 10:37 AM
  2. WTB: Cold Cathodes and Underglow
    By kiltjim in forum Classified Archive
    Last Post: 11-02-2004, 07:45 PM
  3. Lilliput gets dimmer when it's cold???
    By MikeH in forum LCD/Display
    Last Post: 12-26-2003, 07:43 PM
  4. Remote freezes when cold
    By RaZor in forum General Hardware Discussion
    Last Post: 01-01-2002, 11:15 AM
  5. Hard Drive screwed in cold weather!?!!?
    By grandamp3 in forum General Hardware Discussion
    Last Post: 11-23-2000, 12:41 PM
