Page 1 of 4 1234 LastLast
Results 1 to 10 of 31
Thread: Dak Truckputer
    Variable Bitrate Grimey's Avatar
    Feb 2005
    Moody, ME
    Talking Dak Truckputer
    Alright I've been doing enough reading, it's time to start getting my project together, you guys have convinced me .
    This is what I'm looking at for a system.
    Lilliput 7" Touch Screen - Touch Screen
    VIA EPIA MII10000 Mini-ITX Mobo w/ LVDS - Motherboard and Chipset
    Casetronic Black ITX-2699R Mini-ITX Computer Case w/ PCI Riser Card, External PSU - Case
    Kingston 512MB DDR266 Memory - Memory
    CarNetix CNX-P1260 12V DC-DC regulator - POWER!
    The hard drive I haven't decided on yet if I want to go internal or external since I like the thought of being able to bring my Hard Drive into my house etc.
    Also I'll be adding WIFI and Bluetooth hopefully as long as I can find cheap enough which will connect to my Motorola V600 for GPRS access. I'll also have a bluetooth keyboard and mouse in the dash and wire a USB hub into my arm rest in the middle of my truck where there will also be an external firewire/usb DVD burner. In the hub will be a smart card reader for my digicam.
    I'm concerned about the comptuer though since it is 2.5" tall (which I know is tiny!) but my trucks seats sit really low so I have to do some measurements but I'm praying it will fit. The LCD I'm also worried about, I may have to mount it outside of the dash which I'm afraid to do due to security reasons (I go to school in Worcester, city life is harsh, especially in Worcester).
    I plan to watch Circuit City for any amp deals (free installs) so I don't have to deal with that then just wire everything up and cross my fingers.
    Any thoughts, concerns, ideas would be greatly appreciated. Thanks again guys this site has worked wonders for me!
    Constant Bitrate Trazer's Avatar
    Jul 2004
    The Netherlands
    Looks good. WIFI and bluetooth is not that expensive so that probably won't set you back that much. Any reason you didn't mention GPS or just that you don't want/need it?
    As far as the screen goes, maybe a indash tft from digitalww is an option to place the screen. I've learned from experience that plugging and unplugging the screen is a hassle and not very good for the connecters, at least in my case, so that's why i converted my screen to indash.
    Other than that i'd say your good to go. What software will you be using?
    There ain't no need to cry. Time's up. It's time to die....
    Variable Bitrate BiohazrD's Avatar
    Katy TX
    You MAY want to reconsider the Lilliput.
    Bad expieriences.
    Quick! To the Popemobile!
    _
    Mar 2004
    Little Elm, Texas
    a LOT of people have had bad experiences with the lilliputs....A LOT of bad experiences.....but some people either don't have the money for the Xenarc or just don't want to spend the money for the Xenarc.
    BTW - are you on DakotaUSA.com by chance?
    Jan Bennett
    Aug 1999
    Washington D.C.
    How are you going to use that LVDS feature on that motherboard?
    Feb 2005
    Moody, ME
    Quote Originally Posted by Trazer
    My roommate can more then likely hook me up with any Bluetooth, WIFI or GPS software / hardware I need for minimal costs, possibly even free so it's not as much a concern for me. I definitely will have GPS though (I get lost getting out of my drive way ).
    I have looked into the indash tft displays but they seem to expensive for my liking and I might just go with the mounted in-dash and mod my current dashboard, not worry about taking the screen in and out and just get an alarm system of some kind.
    I'm going to build the PC first and get it up and running in my room with Windows Media Center 2005 to start and see where that takes me. I have a feeling I'll end up using XP Pro though or possible triple-boot with Media Center, XP Pro and Fedora Core 3 (linux).
    Quote Originally Posted by BiohazrD
    Bad expieriences.
    Quote Originally Posted by Red GTi VR6
    It is something I'm concerned with, I haven't decided if spending the extra $100+ for the Xenarc is going to be worth it. I don't plan to get the screen for another month or so (need funds and computer comes first) so we'll see what happens a month down the road. Maybe there will be a cheaper Xenarc or something similar. Enough people have said they use the Lilliput though so it's going to be a tough decision.
    No I'm not, but I suppose I should probably join huh? I need to start talking with Dakota users because I've had some problems with it early off and would like some opinions. Are you on it?
    Quote Originally Posted by Zip-Lock
    To be honest, I don't really know what LVDS is yet or what it does. I know it has something to do with Duo-View and LCD monitors and the ability to run dual displays (something I don't plan on yet) but that's about the extent of my knowledge. It's another thing I need to research. Do you happen to know more specifically about it?
    Also thanks for the input guys, it's greatly appreciated, keep it coming!
    Dak TruckPuter:
    Mac: - Researching and Awaiting Funds
    Changed to planning for a Mac Mini Trukputer...w3rd.
    _
    Mar 2004
    Little Elm, Texas
    yeah - we're on DakotaUSA.com 'Blown99CCR/T'
    lots o stuff out there going wrong with them....but they aren't any different than the other cars out there....
    every make and model has it's downfalls and quarks
    Jan Bennett
    Feb 2005
    Moody, ME
    Yea very true. That's awesome, I'll have to join up today.
    I had some real trouble with the idle, would die on my in cold weather, almost got t-boned by a mac truck because of it
    Dak TruckPuter:
    _
    Mar 2004
    Little Elm, Texas
    is it stock or do you have any modifications done to it?
    Jan Bennett
    FLAC IntellaWorks's Avatar
    Jun 2004
    NH
    Wow
    Grimey, wow... your from MA. I've never seen another New Englander on this thread !!! (I'm from NH)
    I actually had my car-pc in an 02 dodge dakota as well if you got any questions let me know..
    Progress [I will seriously never be done!]
    Via EPIA MII
    512MB RAM
    OEM GPS (embedded)
    nLite WinXP pro on
    1GB Extreme III CF card
    Carnetix 1260 startup/ DC-DC regulator
    Software: Still, re-Writing my existing front end in .Net
  1. Check out my newbie truckputer (so far)
    By voidunknown in forum Newbie
    Last Post: 08-29-2004, 02:04 PM
  2. Instant-on screen idea for truckputer
    By f150tech in forum General MP3Car Discussion
    Last Post: 07-06-2004, 04:49 AM
  3. 2002 Z71 Truckputer, DONE!
    By jpainter99 in forum Show off your project
    Last Post: 08-01-2003, 12:13 AM
