Results 1 to 10 of 15
Thread: Please Help, Comp is screwed up!
    Newbie Redeyez's Avatar
    Oct 2004
    San Antonio
    Unhappy Please Help, Comp is screwed up!
    sorry to post this and bother you guys but...
    My computer (not in car, just a laptop) has been crashing like crazy.
    When I start it normally, it loads up normally and launches all my start up programs. As soon as i try to excute a program, however, the screen turns black and it then displays a white on blue screen saying that "something has gone wrong, if you made any changes that probably messed up your computer".
    I booted into safe mode, and ran a virus check on C:\WINNT (I had recieved a message that there was somthing wrong in there but Symantec could not quarentine it). I found the virus, a trojan (located in C:\WINNT\isrvs\sysupd.dll) and successfully deleted it.
    I restarted in normal mode and guess what, it crashed!! I then tried to do system restore, and reset the BIOS default settings. I am now in safe mode with networking.
    Oh yeah, my computer is running Windows XP Pro, service pack two.
    Thanks in advance,
    Tyler
    Maximum Bitrate sfay93's Avatar
    Feb 2004
    Omaha, NE
    ATVMS.com
    Nic
    Nic is offline
    FLAC Nic's Avatar
    Oct 2003
    Melbourne, Australia
    why dont u backup all your stuff and resintall windows
    Signature: [==||========] 20% complete
    Oct 2004
    San Antonio
    -dont know where windows disc is
    -just checking if there was a better way around it
    FLAC TheLlama's Avatar
    Jul 2004
    All over the world
    Congratulations, you just got screwed by Microsoft. Well, you'll need to buy Windows again.. Or if you have your CD-Key you can download or burn a copy and use your CD-Key. Even if you can get around it this time, you will need it in the future. BTW, this should be placed in the "off topic" forum. Oh, if your Laptop is only a few years old, there is a good chance you have a windows installer already installed on your harddrive in a different partition. When you system boots, does it display a message after the POST but before Windows starts up. There is usually a button sequence you hit and it will take over from there.
    Oct 2004
    San Antonio
    llama--sorry about the misplacement, I really didn't know where to put it. sorry to sound like a retard, but what is the POST?
    Feb 2004
    Omaha, NE
    What kind of laptop is it?
    ATVMS.com
    FLAC IntellaWorks's Avatar
    Jun 2004
    NH
    Re-installing windows in this case, should be the last option... I love it when poeple bring thier machines to "Technicians" and they take 10 minutes to diagnose the machine and if it looks "to complicated" to fix they re-install the OS... really are they doing you a survice ??
    Here's my advice..
    Boot to safe mode, COPY the registry... Then run MSconfig, Disable all services but Cryptography & Windows installer and also disable all Startup applications... If the laptop can still go online.. use an online virus scan such as trend micro (something other than the virus scan that you already have)
    I'd like to know if your virus scan is upto date, I'd also like to know what OS your machine is running.... (By the looks its Windows 2000) I'd also like to know if your OS is upto date with service packs... and what were you doing the day before it crashed ??? Did you change anything ?? new hardware ?? anything like that ?? Also.. run a chkdsk /f if it finds some bad sectors keep running it until it passes flawlessly a few times.. report back when you get a chance.. or PM me.
    Progress [I will seriously never be done!]
    Via EPIA MII
    512MB RAM
    OEM GPS (embedded)
    nLite WinXP pro on
    1GB Extreme III CF card
    Carnetix 1260 startup/ DC-DC regulator
    Software: Still, re-Writing my existing front end in .Net
    Feb 2004
    Omaha, NE
    If it is a newer laptop, they usually have a partition that has the repair tools on it. Juat look for the screen when you reboot. Walk through the steps. They are very simple as they are meant for the not so saavy. This will repair your windows installation and you won't lose any files/programs. Takes about half an hour.
    ATVMS.com
    Oct 2004
    San Antonio
    windows xp pro sp2
    i did not do anything that i can think of before it started crashing. All i did was start the burning of a dvd, go to bed, and in the morning it ran okay for about 45 min and bam.
    no new hardware
    im sorry but copy what regestry to where?
    thank you all for you quick replies
  1. Help with comp parts
    By f250crewcab in forum General Hardware Discussion
    Last Post: 08-15-2004, 10:51 PM
  2. gps inside engine comp.?
    By kalito in forum GPS
    Last Post: 02-24-2004, 11:57 AM
  3. 5.1 surround from my comp?
    By stkdidy ntshidy in forum General MP3Car Discussion
    Last Post: 09-17-2003, 09:04 PM
  4. comp wont even Work..pSu
    By samc in forum Power Supplies
    Last Post: 04-27-2003, 11:56 PM
  5. Splicing comp. out
    By All4Norway in forum LCD/Display
    Last Post: 04-02-2002, 11:26 AM
