Results 1 to 10 of 10
Thread: Audio conenction question
    Newbie 0verfiend's Avatar
    Jan 2005
    Chicago, IL
    I have a Hercules Game Theater XP sound card... I was hoping to be able to use this in my setup. It has outputs for standard home components (coax)... are there tutorials, or kits that I can use to connect this to my stock sound system?
    Thanks!
    Elsewhere
    Quote Originally Posted by 0verfiend
    If your stock sound system has AUK inputs.
    How about the Wiki?
    Jan 2005
    Chicago, IL
    Sorry, I wasn't very clear...
    My card has standard RCA outputs (plugs that take these )
    For me to use my car's sound system, I would have to use one of these harneses the one for my car doesn't actually look exactly like that, but you get the idea. I was wondering if there was a simple way to convert the raw wire ends of the harness into RCA plugs without having to rewire every tip.
    I am guessing I will be going the manual way.
    n00b 4 life mp3oplecarrier's Avatar
    Dec 2003
    Chatham, UK
    No, what you need to do is take another look on the back of your head unit and see if you have sockets for the RCA's. If you don't then none of the wires on your harness are going to do the job, and you need to find another way in (aux adapter or modulator)
    Steve
    ....Yes, I know it has a stupid name, those crazy Japanese!
    See me in my wet t-shirt. stevieg's Avatar
    Aug 2003
    Warwickshire, UK
    You won't be able to wire direct to your car audio speakers, unless that ISO style connector goes to an amplifier independant of your current head unit. The common way would be to go from RCA > ICE amp > speakers.
    Another thing is if it's a factory head unit, see if you can get an AUX IN adapter (from www.connects2.com) you need to remember the RCA out on the sound card will not be amplified (or not enough to drive you car speakers!!!)
    Ford Focus MP3 : www.stevieg.org/carpc Blog Updated 29 January 2009!
    Car PC Status: Complete - Undergoing Software Redevelopment
    Jan 2005
    Chicago, IL
    long way back... BUT the sound card has an amp in it... I do not plan on having a head piece in, but want to run all of the stereo through my box. I am 90% sure at this point that it will work.
    My Village Called 0l33l's Avatar
    Jul 2004
    Berkeley, CA
    I think he wants to get rid of his head unit. That harness is probably going to the stock amp.
    Feb 2005
    I too am planning on removing the audio deck in my car. The tape player in it has been dead for quite some time as well as it is a low end stock model. I think his question is, on the connector that plugs into the deck, is there a way to connect that straight to the audio out of the computer? (Id also like to know the answer). If not, then is a amp needed?
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    More information, please! I can't tell what you're trying to do from your posts.
    1. Are you trying to wire the computer sound card directly to your speakers? If so, are you asking whether there are cables sold that fit your car's wiring harness?
    2. Are you trying to run the audio INTO your current stock radio?
    3. Are you trying to run the audio into your amplifier, if you have one?
    Since you didn't specify a) what car you have b) what radio setup you have c) exactly what you are trying to do; we're guessing here.
    Take another shot at it and I'm sure you'll get a useful answer.
    Want to:
    Maximum Bitrate Vchat20's Avatar
    Jan 2005
    Warren, Ohio, USA
    i think what he wants to do is wire it straight to his speakers/amp and get rid of the Hu altogether. what WE need is to know whether or not your car has a seperate amp or not. provide more info about the HU.
    Your everyday carpc geek and tech guru at your service. *bow*
  1. OEM Navigation Connectors
    By Mr Castulucci in forum General Hardware Discussion
    Last Post: 07-20-2010, 06:25 PM
  2. Audigy / Audigy 2 audio question...
    By jasonsp6 in forum General Hardware Discussion
    Last Post: 04-12-2005, 11:04 PM
  3. Carputer to Car Audio Wiring Question
    By Obike in forum Car Audio
    Last Post: 01-13-2005, 07:42 PM
  4. FV24 Audio Question
    By komarak in forum General Hardware Discussion
    Last Post: 01-11-2005, 03:57 PM
  5. Renault Master VanPC and audio hook up question..
    By vintageb3 in forum Car Audio
    Last Post: 12-01-2004, 03:07 AM
