pretty much just check in the various forums, there is a total bad *** install in an e46 M3, you need to check it out for ideas... he dumps the whole unit and builds his from the ground up... he also taps into the ECU to get everything from headlight status to diagnostics... mounted the DVD drive upside down in the sunroof control area...
as far as using the OEM GPS you need to refer to the GPS forum for that one, be sure to search first or they'll bite your head off... the wiring might be complicated but worth it... the truth is a good GPS can be bought for $50... so figure what your time is worth... and maybe look into the more modern shark fin for the GPS mouse to fit in.
good luck, welcome to the carputer world..
LinkBack URL
About LinkBacks
