You could happily use a 8ga wire to ground both devices. These runs will be comparitively short and so the (IxIxR) losses will be much smaller than your long distance run from the battery.Originally Posted by wh0k
Ideally, you want to use the biggest cable possable for ground (especially if the runs are long) as the vast majority of interference and noise problems are ground loop related.![]()
LinkBack URL
About LinkBacks
