Page 1 of 4 1234 LastLast
Results 1 to 10 of 32
Thread: Using a Seperate Battery - for Car Pc
    Nov 2004
    Dayton, Ohio
    Yes I did search but i think this would make a terrific stickie.
    I'm trying to figure out how to add an external battery for my Car Pc set-up. I'm going to get a Optima Yellow Top
    http://www.dcbattery.com/yellow_top.jpg
    From what I've searched this is the best for Car Pc's
    However I'm not quite sure how the wiring will go to make it work.
    Anyone know a site where a layout might be with pictures possible?
    Thanks in advance,
    Vizion
    Stank Cheese n8scstm's Avatar
    Oct 2004
    Eastvale, Ca (Near Corona)
    I have this setup. It works well. I use a sure power isolator from http://www.surepower.com/Products/batiso.asp
    All the instructions come with it. Then you can just wire anything you want from the separate isolated battery. Its called an aux or auxillary battery for future searches.
    2.4 celeron
    150 watt OPUS
    micro atx
    xp pro
    tv/radio tuner card
    audigy
    Dual monitor Radeon
    802.11G Mimo
    xm pcr
    dvd
    gps
    8" Lilliput touch screen
    IGuidance
    dual optimas
    battery isolator
    15" screen
    My Truck
    Raw Wave kickercivic1's Avatar
    May 2003
    Florida
    Dont use isolator. They arent not worth the money. You will loose about a 1or so volt in the back battery. You might as well just take a (+) from the front battery and fuse it closet to the battery, then run it all the way to the back and fuse it again right by the back battery. I have this setup for years now no problem.
    Registered User Dudes99's Avatar
    Dec 2004
    Norfolk, Va
    kicker, different setups for different people. I'm going duals w/isolater due to the fact that I have kneebiters. I went out to the burb this morning and low and behold someone had left the rear map lights on all night. I just don't want to forget about the PC overnight/days if not driven and come out to a dead battery.
    my $.02
    Chris
    Maximum Bitrate 2Fast's Avatar
    Feb 2005
    Bristol UK
    Quote Originally Posted by kickercivic1
    This setup will work, but what Dudes99 says has merit, without the isolator you run the risk of draining both batts.
    FLAC sdashiki's Avatar
    Aug 2004
    Floreeda
    One would think if you planned on leaving the puter in hibernate or sleep mode for any length of time, a second battery with isolator is a must.
    You turn off the car, go inside and sleep. The puter is in sleep mode drawing a few watts. Then 3 days later you try to start your car for work, and the battery is dead. Now while my math of 3 days and a dead battery from sleep mode may be off, it makes a point.
    If you had a second battery that is hooked to an isolator that is hooked to your cars battery, the isolator would only let the puter drain from the 2nd battery. ITs worth the time and money in the long run to be able to always have your carputer ready to go and not need to be started up.
    (0.0%-) starting over
    iPad 3G 64GB, RF 600.5 amp, JL10W0V2, 8 Infinity Components
    Nov 2004
    Dayton, Ohio
    Okay - so can someone show me how to connect the main battery to the isolater to the 2nd battery...there's got to be a tutorial website for this but i cannot locate it.
    Thanks so far guys - I really appreciate all the post so far.
    Keep it up.
    Dec 2004
    Norfolk, Va
    Vizion, if you look at the isolator the posts are marked. I'm sure it comes with directions, Stank? Or if you understand prints:
    Basically, alternator to isolator, isolator to batteries via 2 seperate + cables.
    Dec 2004
    CT
    its fairly easy, from the altinator you have a charging lead(+) from there it goes to the main post on the isolator, then you have 2 posts from the isolator, one for batt.1 and the other for batt.2 now from here depending on your batts and altinator you should run a 1/0 welding cable, some use the performance wire but its all the same your just paying more.Hook the batts. up and your all set.
    EDIT: yup the posts are marked
    Dec 2004
    Norfolk, Va
    Quote Originally Posted by n8scstm
    CAREFUL STANK!!!! You may get accused of nOOb bashing! God I love that "other" thread......
  1. New product - PC Power switch with wired remote
    By hd54321 in forum General Hardware Discussion
    Last Post: 03-08-2006, 10:48 PM
  2. FS on Ebay 12VDC 5.1Ah Ignition Backup Battery
    By TheSpecialist in forum Classified Archive
    Last Post: 03-24-2005, 08:32 PM
  3. Where Shud I Place My Pc
    By xdjxklusivex in forum Fabrication
    Last Post: 01-13-2005, 07:45 AM
  4. MPJA - MECI ASTEC DC-DC Converter
    By Luc in forum General Hardware Discussion
    Last Post: 11-22-2004, 09:31 PM
  5. Xenarc acting strange once installed
    By Sivion in forum LCD/Display
    Last Post: 08-02-2004, 09:30 AM
