Results 1 to 10 of 10
Thread: Extending wiring
    FLAC edrex's Avatar
    Dec 2004
    West Chestinghamshire, UK init!!
    Extending wiring
    My case has an LCD that shows system info. I would like to be able to mount this up front but would need to extend the wires. Attached is a picture of the wires that would need extending. The red/black-black/yellow one is for power. The green/white's are the temp sensors for the HDD, CPU, and system temp monitoring.
    Can I just splice these and add more wire to make them longer? Will it mess up the temp sensor wires if I do this? Is there a place to buy longer ones that will work?
    Thanks all for the help.
    Spent so far: $1,755
    Check Out My Work Log for Specs/Pics
    CarPC Progress[!!!!!!!!!!!!!!].....Installation[---------+].....Pastrami Progress[!!!!!!!!!!!!!!]
    Don't mess with Texas.
    It's not nice to pick on retards!
    Maximum Bitrate grepzen's Avatar
    Jul 2004
    VaBch VA
    Just make sure your splices are sound, & use the same (or slightly thicker gauge wire).
    BTW: this sounds interesting, pics of this -mid progress and finished would be great --please.
    •Micke
    Stank Cheese n8scstm's Avatar
    Oct 2004
    Eastvale, Ca (Near Corona)
    Damn edrex your such an ***. Why do you have to talk to people this way?
    2.4 celeron
    150 watt OPUS
    micro atx
    xp pro
    tv/radio tuner card
    audigy
    Dual monitor Radeon
    802.11G Mimo
    xm pcr
    dvd
    gps
    8" Lilliput touch screen
    IGuidance
    dual optimas
    battery isolator
    15" screen
    My Truck
    Jul 2004
    VaBch VA
    Huh?
    •Micke
    Oct 2004
    Just a reference to something else. LOL. He knows what I mean.
    2.4 celeron
    150 watt OPUS
    micro atx
    xp pro
    tv/radio tuner card
    audigy
    Dual monitor Radeon
    802.11G Mimo
    xm pcr
    dvd
    gps
    IGuidance
    dual optimas
    battery isolator
    15" screen
    My Truck
    FLAC edrex's Avatar
    Dec 2004
    grepzen: I'll do my best to get some good pics. If it works out how I want it to, then it should be a pretty cool little setup. Thanks for the advice on the wires.
    Quote Originally Posted by n8scstm
    Sorry man. I forgot my Midol this morning...
    Jul 2004
    VaBch VA
    One last consideration I just thought of:
    those two sets == power and signal.. the power, I'm certain is DC.. you may get some noise on the signal wires if they're run in close proximity to data.
    If you can run at least one of those sets through a shielded conduit that would help any alieviate possible noise problems.. maybe a 'dry fit' test outside the car (if possible) might prove or disprove the need for this step.
    •Micke
    FLAC edrex's Avatar
    Dec 2004
    Awesome, thanks!
    I was thinking that maybe I would mod the wires to the length I need, and then hook it all up and see what happens. Hopefully it all works out.
    FLAC edrex's Avatar
    Dec 2004
    Can someone tell me what those connectors/wires I posted in the first post are called. I want to look for some longer ones but I have no idea what they are called!
    FLAC ppgt94's Avatar
    May 2001
    USA
    Quote Originally Posted by edrex
    Unfortunately I don't know the name. But I was curious how long you want to run them? They seem awfuly thin to run from a trunk to up from in dash. It might work without problems but I would like to second the idea of extending them yourself with a bit thicker gauge wire.
  1. Pioneer Aux interface.... wiring up ... how?
    By Kenny in forum General Hardware Discussion
    Last Post: 06-27-2009, 05:56 PM
  2. Innovatek wiring....lights never go out....
    By myykk in forum LCD/Display
    Last Post: 03-08-2006, 12:12 AM
  3. Inverter Wiring
    By MoniraInc in forum Power Supplies
    Last Post: 06-25-2004, 08:23 PM
  4. datalux 4x20 red lcd wiring diagram?
    By etrik in forum LCD/Display
    Last Post: 12-07-2001, 03:35 PM
  5. Specific wiring schematic 4 Optrex DMC40457?
    By sooty in forum LCD/Display
    Last Post: 07-17-2001, 02:11 AM
