Results 1 to 2 of 2
Thread: Aerogate3 Cooling Fan Controller
    Feb 2005
    Hi all! Noob question here. I'd like to use the aerogate3 to monitor and cool my car audio amps, and I'm trying to figure out how best/safe to kook the controller (comes with 4-pin molex PS connector) to the car battery. Do I need the DC-DC Regulator? Thanks!
    Maximum Bitrate mushin's Avatar
    Aug 2004
    SE Michigan
    I'm not familiar with the aerogate3 (quick search shows it's a temp/fan monitor/controller?) but if it's expecting clean power from a PSU, you should regulate the car power. Also, if it uses 5V (4-pin molex carries both 12V and 5V), you would need to use a voltage step-down.
    I'd ask why you're connecting it directly to the battery rather than the PSU (you do/will have a computer, right? ), but I'm sure you have your reasons.
  1. Do you need a very compact graphic fan controller?
    By more mods in forum LCD/Display
    Last Post: 09-24-2004, 07:17 AM
  2. Xenarc VGA Controller Features
    By 1300mer in forum LCD/Display
    Last Post: 07-05-2004, 01:46 PM
  3. Case fan modified. Safe?
    By cafn8 in forum Off Topic
    Last Post: 03-18-2004, 11:57 AM
  4. cooling fan color code
    By albysure in forum General Hardware Discussion
    Last Post: 07-03-2003, 11:43 AM
  5. low profile high cooling fan?
    By spyhunter in forum General Hardware Discussion
    Last Post: 08-12-2002, 05:56 PM
