Results 1 to 10 of 18
Thread: Inverters and power drawn
    Feb 2005
    Let's say my carpc draws a constant current of 200W. Is a 500W inverter draw more power from my alternator than let's say a 300W one.
    Feb 2005
    Yes or No would do it....thanks
    _
    Mar 2004
    Little Elm, Texas
    I could be wrong here, but I'm going to bet that that inverter isn't going to put out it's max wattage rating at all times....just like a regular amplifier....it has the capability of putting out a MAXIMUM of 500 watts. If you are only demanding 300 watts from it then it will only supply 300 watts.
    Make sense?
    Jan Bennett
    MySQL Error Scouse Monkey's Avatar
    Mar 2004
    Bristol
    As red says, input is proportional to load.
    EDIT: oops, composing replies in word as i am in work and pasted two answers so deleted it before anyone asks!
    Feb 2005
    Correct. draw = (load) + (no load draw)
    No load draw is a constant. It's pretty low for most inverters but will still kill your battery over a week or so.
    Maximum Bitrate mushin's Avatar
    Aug 2004
    SE Michigan
    Mm, to be a little nitpicky, not exactly. The inverter will likely have a non-flat efficiency curve over power draw. So it may, for example, be 60% efficient at 50% load, and 70% efficient at 100% load. I doubt it'll make much difference, but I would expect a little difference.
    Aug 2004
    SE Michigan
    Quote Originally Posted by Red GTi VR6
    Make sense?
    You're absolutely right that a 500 watt amp will only supply 300 watts to a 300 watt demand, but it will draw more than 300 watts. Class A amps are particularly horrible in this sense, as their efficiency plumments at lower outputs (they basically bleed off the extra power). Class A/B is a bit better, but not exactly great. Class D is the exception, being switched.
    _
    Mar 2004
    Little Elm, Texas
    well, that is correct, but isn't that going a little overboard when trying to explain the answer to this guy?
    Jan Bennett
    Feb 2005
    thanks, thanks, thanks....
    just have to find a class d inverter
    Feb 2005
    My thoughts exactly. LOL. This is a newbie forum after all.
  1. sine wave power inverters
    By fuctup in forum Power Supplies
    Last Post: 12-13-2004, 04:02 PM
  2. Power Inverters
    By SweetLikeChutny in forum Power Supplies
    Last Post: 11-03-2004, 06:50 AM
  3. Power Inverters (Pure Sine?)
    By brain21 in forum Power Supplies
    Last Post: 11-02-2004, 04:07 PM
  4. Consenus on quality Power Inverters and FM Modulators
    By dodgetimes2 in forum General Hardware Discussion
    Last Post: 04-14-2004, 09:21 AM
