Results 1 to 2 of 2
Thread: Install Order
    Dec 2004
    Los Angeles, CA
    Install Order
    Hi, I have had trouble in the past with my XP installation, and my carputer taking about 6 minutes to start up. I think its all because of the software install, because after a nice, clean format, it will work flawlessly, and as I install software and other crap, it just doesn't start up for another 6 min. I have tried too many things, and none works. Bios reset, changing settings in the BIOS, formatting HD, etc.. So here's what I ask from you, tell me the order you think I should install the following.
    • Touchscren Drivers/Software (Hub 1)
    • USB DVD Player (Hub 2)
    • USB Bluetooth Adapter (Hub 3) *
    • D-Link USB WiFi Drivers
    • Rikaline 6010 GPS Drivers / Routis
    • Radioshark Drivers / Software
    • Centrafuse 1.20
    • Copying files over from network
    • Any other software I'm missing
    * I think that this might have been the problem last time, so I'm a little hesitant on installing it, but it is necessary for my carputer.
    Thanks for the help!! I really appreciate it.
    Raw Wave RoyN's Avatar
    São Paulo, Brazil
    I'd do one by one and see where the problem is.... that would sound logical wouldnt it.............................
    Either way id do the following:
    Touch
    [time boot times]
    Copy files
    [time boot]
    CF requirements
    [time boot]
    then (time boot between each) CF itself, GPS, dvd, radio, bluetooth
    you get the point, but time between each boots so u get the problem...
  1. 2002 Montero Limited Install...
    By Squid in forum Show off your project
    Last Post: 10-06-2009, 04:41 PM
  2. xp install to laptop hdd problem
    By thecrow in forum Newbie
    Last Post: 06-15-2005, 04:37 PM
  3. software install order
    By hihidamon in forum Newbie
    Last Post: 12-21-2004, 09:00 AM
  4. How should i install this?
    By jnusaira in forum General MP3Car Discussion
    Last Post: 08-13-2004, 04:03 PM
  5. Where does ground loop isolator install?
    By grandamp3 in forum General Hardware Discussion
    Last Post: 09-14-2000, 09:10 AM
