Results 1 to 9 of 9
Thread: How to test Car LCD Monitor at home?
    I just purchased a motorized in-dash LCD Monitor from Ebay, and I was wondering if it is possible to test this unit out at home? If so, how would I go about it? Thanks.
    Jan 2005
    you co7uld wire a cig plug to it and use a 110-12v adapter or
    you could use a car batt-charger(have never used it on anything a sensitve as a screen though)
    Maximum Bitrate Danceheaven's Avatar
    May 2002
    Essex, UK'er
    Quote Originally Posted by yonu
    i wouldnt use a car batt charger there not very stable
    just find a 12v Regulator and use that
    Co Develper of A.I.M.E.E Automotive Intelligent Multimedia Entertainment Engine
    www.aimee.cc
    Nov 2004
    Netherlands
    Car charger is not recommended, it's not stablized, its DC, but thats all..
    I suggest to get a generic powersupply at your local electronics shop, e.g. the ones used for CB radio's. They can give 3-5A for the easiest model.
    I myself have a regulated powersupply, since i'm much working with various products. Its adjustable from 3-20V, up to 10A. However, thats quite expensive just to test your screen.
    Cheapest way to test your screen: Use the 12V from your computer, or use an old AT powersupply.
    MySQL Error Scouse Monkey's Avatar
    Mar 2004
    Bristol
    just get a molex V lead from a PC/electronics shop and wire up to your PC PSU. Use a female ciggy lighter socket or make your own lead with a new connector like the one on your screen. Jsut make sure you get the right polarity.
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    I also have a 12 volt regulated power supply but that's gonna run you around $70. I have also used one of these portable car jump starters that has a little 12 volt battery in it on one side and an air pump on the other. Conveniently, it has a cigarette lighter socket in it as well. I think those are a bit cheaper and who knows, maybe it will come in handy jumping the car one of these days.
    Want to:
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    Why not use the stable 12V from the PC PSU drive connector?
    +12V is yellow and - is black. Red is +5V and you don't need it.
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
    Newbie skellum's Avatar
    Feb 2005
    California
    i took the easy way out when my screen arrived (ebay).
    popped the hood, wrapped the wires around the battery leads directly (my leads had inline fuse).
    plugged the screen into the laptop and watched it come to life.
    as far as the power supply suggestions, you "can" steal power from a computer power supply.
    (http://www.hut.fi/Misc/Electronics/c...r_from_pc.html)
    How to get power from inside PC
    Disk drive connector
    Normal floppy disk and hard disk drives use normally +12V and +5V power supplies, so spare disk drive power connector is very useful if you need those voltages for your own projects which you fit inside PC (for example extra fan for better cooling). Typically you can take up to few amperes of power form the disk drive power connector (remember not to exceed the total power rating of the PC power supply when you start taking extra power for your circuits).
    Here is the power connector pinout when you look the CEE-type connector on the drive back:
    _______
    |1 2 3 4 |
    |________|
    Pin Function
    1 +5 V
    2 Ground
    3 Ground
    4 +12 V
    by the time you go down and get a plug and make a pigtail, you will probably end up just hooking up to your battery.
    Maximum Bitrate clean customs's Avatar
    Jan 2005
    Houston
    Another way is to take a power supply for most eletronic components like your laptop, and splice the wires after the "little black box". Most components run off of 12Vdc instead of 120vac, so you can use any of those power supplies, or most of them. The black box you plug into the wall normally outputs 12V, and it will say the voltage out put. You normally don't have to cut the wires, but just split them and strip it off to connect the wires to. And then just tape them up when your done. PLEASE check which one is positive and negative before you splice it in. Thats the way I run some twelve volt things, specifically my PC when I need to work on it in the house instead of sitting in the car for hours and killing myself with fumes in the garage. Plus it creeps the neigbors out.
    Round VIII - [IIIIIIIIII] 30% Have some parts for 300zx Sema car I don't own yet. Will have 10.4" & 7" screen, and more then you can believe. Will add updates to cleancustoms.com, will be sweet. My car is still same, but might change.
  1. how to show car speed, rpm, etc. on lcd?
    By Chroniccodez in forum General Hardware Discussion
    Last Post: 05-20-2006, 07:38 PM
  2. Replies: 6
    Last Post: 08-22-2005, 02:10 AM
  3. 14" lcd Home screen???
    By zman009 in forum LCD/Display
    Last Post: 08-20-2004, 08:28 PM
  4. FS: Car Computer Setup - Everything you need!! Pics Galore
    By EBoundEE in forum Classified Archive
    Last Post: 06-19-2004, 10:41 PM
  5. converting home lcd to mobile
    By bsostack in forum LCD/Display
    Last Post: 08-30-2003, 06:33 AM
