Results 1 to 5 of 5
Thread: 1500 Watt Inverter - An Overkill???
    Feb 2005
    Gents, (Ladies too if there are any)
    I've just acquired a 1.5kW inverter that could be part of my car PC setup. Just wondering, is this a significant overkill, to be the point it might be detrimental to my car?
    Malaysia
    -Alfa Romeo Giulietta 1982 with 1992 Alfa 75 2.0 Twin Spark Engine-
    Mar 2005
    Yes....
    a pc at most is 400-500watts and thats a full blowen desktop pc. But the unit is only going to draw the amount of power that is needed. Just remeber p(watts) = volatge x amps. So p/v = amps... 1.5k watts/14 vlts = 107amps which is more than most car alternators put out, so be carefull.
    Well, He asked for it. WebDog's Avatar
    Los Angeles, CA (West LA)
    It really depends on what you want to run. I would stick it in and see if it hirts your charging system.
    1990 Jeep Cherokee
    2000 VW Golf TDI 4dr
    2005 VW GTI MKIV - SOLD
    Maximum Bitrate mushin's Avatar
    Aug 2004
    SE Michigan
    Hey, this is where the post I was derided for being "too detailed for newbies" (paraphrased ) in this thread actually has some use!
    Inverter efficiency varies with load - I guess a typical peak efficiency is around 60% - 70% load, and worst efficiency tends to be at very low loads. If you have a relatively small load (100W - 200W is pretty common around here, my guess) on such a large inverter, your efficiency might be pretty bad. Or it might be okay - check the specs for your inverter if you can.
    Feb 2005
    Thanks for the input guys. I think I really need to look up on my alternator first. Its got a max rating of 90 amps, hence it would definitely not power the inverter to the inverter's max rating.
    Malaysia
  1. Replies: 11
    Last Post: 02-21-2005, 09:52 PM
  2. For sale or trade: 600 watt inverter
    By lstrunk in forum Classified Archive
    Last Post: 05-25-2003, 12:38 PM
  3. For sale on ebay 300 watt power inverter NEW
    By mp3pc in forum Classified Archive
    Last Post: 08-23-2000, 12:02 PM
  4. 140 watt inverter
    By btomasie in forum General Hardware Discussion
    Last Post: 05-19-2000, 12:16 AM
  5. 300 watt power inverter problems
    By DaPyro in forum General Hardware Discussion
    Last Post: 03-10-2000, 03:56 PM
