Results 1 to 4 of 4
Thread: Yellow top tank battery
    Newbie Ripsurf's Avatar
    Jun 2004
    Southampton, UK
    HI All...
    Im thinking about running a second battery and looking into a Yellow Top battery as the second battery. This is the one im thinking about using http://cgi.ebay.co.uk/ws/eBayISAPI.d...e=STRK:MEWA:IT
    Im going to join the main and the second battery with a relay so they are both connected to each other when the engine is on.
    Just like to know if this is going to be good enough to run the pc for a while when the engine is off. Im also thinking about getting this power inverter so i can run a full spec pc http://cgi.ebay.co.uk/ws/eBayISAPI.d...e=STRK:MEWA:IT
    Thanks In advance
    Feb 2005
    Two batteries is always good if you have the space and hook them up so the main battery charges first.
    Not sure you want to run an invertor and full size PC though. THere is only so much you can do and so much room in a car/truck to fit everything. I say go with the new Opus or the new Carnetix (both to be out really soon) and run a nice P4 m-ITX system.
    Brent
    1999 Nissan SE-L - turbo toy
    1993 Nissan NX - Turbo Racer
    Standalone fuel management (AEM EMS) on both
    carPC
    Jun 2004
    Southampton, UK
    OK thanks
    Didnt know Opus are bringing out a new power supply
    I have a opus 150w at the moment and a m10000 system board with 256 mb Memory, gps, wirless etc. Could not live without a pc in the car now
    I just like to leave the pc on without the main battery going flat just so i can transfer files ect
    Ok then i will buy one of the Yellow top batterys
    Would the relay be the best option to join and disconnect the batterys though
    Thanks again
    See me in my wet t-shirt. stevieg's Avatar
    Aug 2003
    Warwickshire, UK
    Quote Originally Posted by Ripsurf
    OK thanks
    Thanks again
    Have a look here, or alternatively search for Tank Circuit
    Battery based tank circuit (tested)
    Ford Focus MP3 : www.stevieg.org/carpc Blog Updated 29 January 2009!
    Car PC Status: Complete - Undergoing Software Redevelopment
  1. Battery based tank circuit (tested)
    By Ricky327 in forum Power Supplies
    Last Post: 02-13-2008, 05:43 PM
  2. Qn about gel batteries as tank battery
    By SteveC in forum Power Supplies
    Last Post: 01-12-2005, 02:43 PM
  3. FS: SF Bay Area: Optima Yellow Top
    By VanMan69 in forum Classified Archive
    Last Post: 08-19-2004, 04:17 PM
  4. Problem with tank battery - any good Plan B?
    By Mastiff in forum Power Supplies
    Last Post: 06-14-2004, 10:10 PM
  5. Not grounding tank battery?
    By lgbr in forum Power Supplies
    Last Post: 06-10-2004, 01:29 AM
