Results 11 to 20 of 28
Thread: How fast does your computer boot?
  1. #11
    Self proclaimed spoon feeder TruckinMP3's Avatar
    Jun 2002
    My celeron 300a comes out of hibernate in about 45 sec, my old p200 mmx did a cold boot in 2:44 (M:SS) most of the more current hardware will be faster...
    Read the FAQ!
  2. #12
    Super Moderator xBrady's Avatar
    Quote Originally Posted by Osiris
    What are you running TimmyM and brady?
    Look in my signature.
    -GPSSecure- - GPS Tracking
  3. #13
    Aug 2004
    I use a P3 1.0 and a 2.0 celeron, both with 512mbs ram, running stripped-down xp pro. I'm going from turn on to music in about 12-15 seconds using hibernation, and I haven't really dug that deep into windows. Just do the obvious stuff, turn off all the auto-update, restore point, etc.
    I find the music starts playing about 3-4 seconds before I see anything on the screen. By the time I'm sitting in the seat, put my belt on, check my vitals, and put it in gear, the music is playing and I'm off.
  4. #14
    Maximum Bitrate TimmyM's Avatar
    Aug 2003
    Federal Way, WA
    Quote Originally Posted by TimmyM
    You could be flamed like crazy, BUT you did ask your question in the "Newbie" area so I guess we'd have to let it go. I have a Celeron 1.1ghz with WinXP Tablet edition, and it is on par with Xdjklusivex. Actually 36 seconds from hibernation until music. Think I could look into why it takes so long but the 36 seconds doesn't seem to bother me enough to do so. It was twice that when I tried using a TV board, i never got any reception so I removed it and now it's back to 36 seconds.
    As I said. I also have 256megs of ram.
  5. #15
    Aug 2004
    Well I just timed mine and it was 50 seconds from pressing power button until I could press start in XP. Slighly worrying since I thought it was quite quick - I would say that the bios boot was about 15 seconds then xp was the remaining 35! This is loading of an standard version of XP with an IDE harddrive. If I was to use a CF card with an nlited version of XP would there be a considerable difference? Thanks.
    oh board is m10000
  6. #16
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    My M10000 takes over a minute to boot from scratch. But I hibernate it and it comes on in about 45 seconds. It doesn't bother me too much as it's usually playing by the time I've adjusted everything and begun to pull out of the driveway.
    I think the consensus is that a CF card doesn't really speed things up appreciably. It's the nLite install that helps the most.
    If speed is really important to you, use a tank circuit and run it in standby. It awakes from standby very quickly.
    Want to:
  7. #17
    My man uses Levitra. Peoples's Avatar
    Dec 2004
    my 1.7ghz come out of hibernate (thanks to my new hibernate hack....didnt have it before) about 18 seconds. Without hibernate it takes a good 40 seconds to play music.
    Edit: ok, realized that since I had reset my bios, the 1.7 mobile was being recognized as a 1.2 again. I fixed this and tested the speeds again. Comming out of hibernate is about 15 seconds. Cold boot is now exactly 30 seconds. Also at the moment I am running 256 megs of ram and not 512, doubt this makes any difference.
    PC Components:
    My work log
  8. #18
    Nov 2004
    South West
    on a related note, how do i get my pc to load up the front end software and start playing when i turn on without having to click anything?
    PB 2.0Ghz, 20GB, 512mb, XPpro. 300GB Usb HDD, Griffin pwrmate, m-audio audiophile fw. BU-353 gps. 2x100w sony amps, 1x150w JBL sub amp, MBQuart front components, 6x9 rear, 10" sub. Audiocontrol epcienter, esp2, 3xs. Clifford G5, Finished, fitted, problems
  9. #19
    MySQL Error jcdillin's Avatar
    May 2003
    Miami, FL
    put a shortcut to the program into the startup folder on the start menu
    the function for the frontend to start playing music will be dependant on the frontend
    S60 Install
  10. #20
    Constant Bitrate superbowl's Avatar
    Jan 2005
    can anyone with a super-fast boot-time (< 30 seconds) please post a video and some instructions ?
    on my epia M10000 it takes at least 5-8 seconds for the bios to start up, the harddisk and dvd-rom takes another 8 seconds, so its 16 seconds before windows xp starts booting.
    playing music after 20 seconds... i really like to see that.
    - superbowl
    i never drink water cos fish ***** in it. (w.c. fields)
  1. I cant get my computer to boot my CF Card
    By csnowman00 in forum General Hardware Discussion
    Last Post: 03-15-2005, 12:10 AM
  2. Need help optimizing Win2k for fast boot
    By R32 JUhl in forum WinNT Based
    Last Post: 03-09-2005, 04:48 PM
  3. My computer wont boot! Help.
    By Rith in forum General Hardware Discussion
    Last Post: 02-17-2005, 12:30 PM
  4. Prob w/ 8" Lilli ts. flickers after boot.
    By Ninety8NeonACR in forum LCD/Display
    Last Post: 05-07-2004, 12:55 AM
  5. computer remote control
    By agent_86 in forum General Hardware Discussion
    Last Post: 10-18-2002, 02:36 PM
