It should.
After Reading the "Sticky HOW TO: Get sound from PC to Car Stereo / Amp" I have a question.....
I have a HU Kenwood KDC-352 (No Aux Input) and I have a Sirius Satellite Radio Tuner Kenwood KTC-SR902, they are connected using a CD Changer Cable (13 Pin Male) One end to the HU and another one to the Sat Radio....
The Sat Radio Tuner has another input where you can "cascade" a CD Changer or an MP3 Keg using the same Interface Cable (13 Pin Male)
My question is.... Can I connect the Audio from the puter in the Input of the Sat Radio Receiver ?
Will it Work ?
It should.
this should do the job..
http://www.caraudiodirect.co.uk/prod...products_id=87
Good find!
If such a cable can emulate a changer on the hu directly, it should be able to do so on the sat-tuner also...
Just make sure that connector has 13p![]()
You Rock Guys !
http://www.mictronics.de/?page=cdc_proto
The second article on this page has some nice info if you want to dig deeper (more control than just sound-input).
here: http://home.wanadoo.nl/patrick.loef/ you can check out the data-connection that's also part of the 13p cable (and even a diy-cirquit).
