Results 1 to 3 of 3
Thread: Replanning CarPC
    Feb 2005
    Replanning CarPC
    After being on this site for a while I decided I have to totally replan my carpc build. My only two goals for this project are to have navigation and DVD video under $600. I originally thought that an old PII 266Mhz processor would be able to tackle this, but after some feedback on here I realized that is not going to be good enough. So, I decided since im starting from scratch I would go Laptop instead of desktop components. This would save me the hassle of having to buy a shutdown controller since that can be setup in the laptop itself as well as everything being much more compact. So, I found an IBM PIII 800mhz laptop for a good price. Is this sufficient for my use? If not, what would be the minimum processor type/speed that i would need?
    FLAC IntellaWorks's Avatar
    Jun 2004
    NH
    feedback
    I'd say a PIII or any processor higher than 433 MHZ could process DVD's just fine.. in fact your 266MHZ idea probably would have been fine to process just dvd's... of course you want to throw navigation in there.. so your going to need a bit more power.. hence the recomendation for anything higher than a 433... if you know what nav. software your using then check the specs out for that and see what it requires..
    personally a PIII 733MHZ with 256 MB would handle anything you'd throw at it and maybe then some.. hope this helps sorry my ideas are kind scattered.. but i'm at work and no time to organize ideas !!!
    Progress [I will seriously never be done!]
    Via EPIA MII
    512MB RAM
    OEM GPS (embedded)
    nLite WinXP pro on
    1GB Extreme III CF card
    Carnetix 1260 startup/ DC-DC regulator
    Software: Still, re-Writing my existing front end in .Net
    MySQL Error jcdillin's Avatar
    May 2003
    Miami, FL
    my sony laptop which is only a 600Mhz P3 works just fine with DVD and NAV, just make sure you get 256MB of ram or you might run into some troubles.
    肚子笑痛了
    S60 Install
  1. Connecting CarPC to the Speakers
    By Matthew230 in forum Car Audio
    Last Post: 05-27-2008, 05:28 AM
  2. CarPC PictureViewer! works with ALL engine
    By dragonBTV in forum Software & Software Development
    Last Post: 02-02-2005, 09:56 PM
  3. Loud noice when turning on CarPC
    By Andreas106rally in forum Car Audio
    Last Post: 11-03-2004, 12:27 PM
  4. Replies: 4
    Last Post: 06-29-2004, 09:20 PM
  5. CarPC Software Launcher
    By Confused in forum Software & Software Development
    Last Post: 05-01-2004, 01:10 AM
