You really don't need a RAID for a carputer. What are you reasons for using a raid?
Ok, I did aand didn't come up with anything, so hopefully I won't get flamed for asking this question.
I know that RAID 0 (disk striping) speeds up read times, but doesn't usually help boot-up speeds simply because RAID controllers take several seconds to initalize the array. So my question is, are there any RAID controller cards or built-on controllers that don't take that long, perhaps ones that can save a setting and recall instantly on bootup?
Also, are RAID array speeds any different for SATA vs. PATA hard drive arrays?
No. RAID controllers have their own BIOS that needs to initialize. That adds to the POST time. You can't get around it.Originally Posted by gardocki
SATA drive arrays are faster simply because they can transfer faster. It's not so fast that you'd notice the difference, though.Also, are RAID array speeds any different for SATA vs. PATA hard drive arrays?
LaserLine is correct. You don't need a RAID array in your car. You're daft if you think you do.
Will increase boot times, power consumption and heat.
Plus, all current "SATA" drives are just PATA drives with another chip on them to convert them to SATA connectors. Therefore they are no faster. Especially as all these drives are still only 7200 RPM.
The exception to this is the Western Digial Raptor which is a native SATA drive with 10k RPM.
Garry
Co-Developer of A.I.M.E.E
www.aimee.cc
And will also increase your likelihood of having a fatal error, as there are now two big spinning disks waiting for the heads to crash into the plattersOriginally Posted by UK_MP3Car
www.aimee.cc
late 7200.7s were seagates first native satas
As for a stripe, dont do it - seriously you wont do yourself any favours if it crashes.
BUT, ive long pondered how effective running RAID1 mirror for redundancy would be- Its a bit academic atm since I have not got my instal complete but one thing that worries me is people here reporting HDD crashes or corruption and I wonder if a mirror setup might save the day, instead of having to reload an image (or worse, reinstal from scratch).
The jurys out on that one, plus many are starved of PCI slots so would find it hard to add a raid card on anyway.
I recommend a 3Ware Escalade pci card. It will run you about $130+ but it is quality, but why do you need raid in the car? those are the cards i run in my servers and they are great.
1990 Jeep Cherokee
2000 VW Golf TDI 4dr
2005 VW GTI MKIV - SOLD
I beg to differ.Originally Posted by DarquePervert
I run a software RAID-5 array of 3x300GB 5400rpm drives. Why? Because I like the idea of having all of my music available to me, whenever I might want it. Bowie's "Life on Mars?" - no problem. Radiohead's "Creep?" - right here. Chopin's "Revolutionary Etude?" - gotcha.
I'd like to state, DarquePervert, that when one knowest not whereof one speaketh, one's mouth is best used for chewing.
1) Unless your in a mission critical environment, allocating three HDDs to get the redundant, striped storage space of one HDD is excessive, in my opinion. You get some geek cred points, though.Originally Posted by rubicon
2) You don't need a RAID array in a car, period. You state very plainly that you like the idea of having whatever tune available whenever. You don't need it.
3) If redundancy is important to you, a RAID 1 array would be a lot cheaper to pull off than RAID 5 and would have fewer points of failure. That's something that I'd deeply consider in a harsh environment like a vehicle.
4) You're runnign a sotware-controlled array. This discussion is of hardware-based RAID controllers. You're comparing apples to oranges.
I'm not putting down your RAID array in your car. I can certainly appreciate your logic behind it. 100% uptime is always a good thing. I think the risks & expense outweigh the benefits in this case.
