Results 1 to 7 of 7
Thread: Hello, some questions by a newbie...
    Low Bitrate GibsonLP's Avatar
    Mar 2005
    Israel
    Hi there,
    I would like to start planning my carpc, I know what I want, I have some idea how to do that (mostly on the software side, being a unix sysadmin for almost 10 years now... yes, of course it would run Linux ) and I know my car's limitations (hu must fit into the regular dash slot)
    So here it goes:
    My needs/wishes:
    A semi-powerful X86 computer (something comparable to pentium 4 2Ghz and up), with half a gig of RAM, I was thinking to boot off a CF card, but after reading a little bit here I saw that a laptop drive should survive...
    It would run Linux and hopfully would have the following features:
    1. MP3 player (easy)
    2. GPS (should be easy, never done that on Linux)
    3. DVD player (mplayer rocks)
    4. (hopfully) OBDII connection (no idea how to do that, yet) so I can see my Audi's diagnostics on the fly...
    5. (hopfully) cellphone integration via bluetooth (no idea how to do that)
    6. (maybe, if the hardware supports it) wardriving (although I am not in this "scene" anymore - this option could be nice )
    I currently have my own audio system and I plan to use the existing amps.
    My problems/questions:
    1. Since I don't have enough space in the dashboard (just a regular CD slot space...), where would you recommend to put the pc itself? I thought about getting an indash LCD/touchscreen and put the PC under the passanger's seat.
    2. Is there an indash LCD + DVD combo? - I know that IDE would have problems travelling all the way from under the seat to the dash, maybe there is a USB DVD+indash VGA? - Couldn't find either on google.
    3. What about cooling requirements? is the "under the seat" location suitable cooling-wise?
    4. How much noise does the OPUS unit for example produce?
    I don't have enough experiance with welding stuff, so I guess I'd buy everything and just assamble the stuff myself, what would you say about the OPUS system?
    The only problem I see with it right now is that it is a bit under-spec'ed, however - for the list of things I would like to do with this machine it should suffice (I am a power-holic )
    What do you say about http://www.cartft.com/carpc/catalog/il/480 ?
    Oh yeah... budget - well, actually there is no actual limit right now, I would love to stay around the $1000-$1300 though.
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    Quote Originally Posted by GibsonLP
    Ditch the CD player. Put a slimline drive in it's place.
    Several people have extended their IDE cables quite far with no ill effects. Search on "IDE cable length" or "IDE extension" or some variation to find posts on the topic.
    It should be, as long as the vents aren't covered up.
    Don't have one. Don't know.
    I don't know much about the OPUS systems.
    Right. You just don't need that much power for what you want to do.
    You are planning on turning it on and off...how?
    That's do-able.
    One thing you might consider is setting the system up as dual boot Windows/Linux. There are tons of programs that will do everything on your list for Windows with very little difficulty. Linux will be a different story and while you're working on getting all of the apps to run, you can have the Windows install and all of the working program.
    By the way, an odd idea might be to get a mac mini if you're experienced with Unix. The case you linked to is practically the cost of a mini before adding the processore and memory. Some people will recoil in horror at this suggestion. I'm just throwing it out for your info.
    Want to:
    Self proclaimed spoon feeder TruckinMP3's Avatar
    Jun 2002
    Colorado
    Desktop drives are fine for incar use as well. the amount of storage per dollar is better than laptops.
    TruckinMP3
    Read the FAQ!
    Raw Wave wizardPC's Avatar
    Jun 2000
    Nashville
    [shameless plug]
    I have a system for sale that will do everything you want it to do. It comes with a slimline USB DVD/CDRW so extending the IDE cable wouldnt be an issue. Check out the link in my signature
    Don't know how much shipping it to Israel would be though...
    [/shameless plug]
    Debt as of 1/1/05: $34,354.48
    Debt as of July 4, 2007: $0.00 explanation
    Total spent on wedding so far: $3885.79
    Thanks to everyone for your support.
    I'M DEBT FREE!!
    Mar 2005
    Israel
    Hi there and sorry for not replying sooner...
    Thanks for the answers, I have decided to get a used laptop with a damaged screen (+-$300, free in my case...) as the computer and simply put it under the seat, I need it to be stealthy and laptop would be great size-wize (and also cheaper than any other combination).
    WizardPC - sorry, but I won't buy your computer, as tempting as it sounds - I already have a laptop I can use for it, thanks for the kind offer anyway!
    A few new questions:
    I'll need to buy an external sound card as I don't like the 1/8" PLs...
    I want to be able to have the same controlability as I have now in my audio system - L-R balance and F-R balance + Subwoofer control, that means that I can't live with a normal stereo sound card, even though I can get the creative MP3+ VERY, very cheap, I thought about using the computer as a stereo input device to a regular audio system that can control the speakers indevedually like I have now - but I need the 1 DIN space on the dash for the in-dash VGA... so if you have any suggestions - shoot...
    Does the live! 24 external capable of controlling the outputs for each indevedual channels? can it work as 4.1? as well (instead of 5.1).
    Thanks!
    Mar 2005
    Israel
    Anyone?
    Thanks.
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    I'll preface this by saying I know JACK about car audio. I do, however, know that a lot of people use the audigy sound card for higher end applications. It will probably do what you're asking.
    Want to:
  1. Newbie here. Introduction and some questions...
    By 3Point4Tacoma in forum Newbie
    Last Post: 07-22-2004, 01:41 AM
  2. Replies: 4
    Last Post: 04-18-2004, 11:50 PM
  3. A few newbie questions ( heat issues etc.. )
    By Scorpnstail in forum Newbie
    Last Post: 03-05-2004, 05:27 PM
  4. some newbie questions
    By huntD in forum Newbie
    Last Post: 11-24-2003, 04:21 AM
  5. some questions for a newbie
    By mr2 in forum Newbie
    Last Post: 11-19-2003, 04:40 PM
