Results 1 to 5 of 5
Thread: Power (no not your normall question)
    Mar 2005
    Ok, instead of going down the stand carputer root I have decided to get a laptop instead....
    This means i can get a laptop car charger cut the cig lighter end of and wire it in....
    one problem, how to turn it on....
    any ideas, itll be held in the boot. The only option I can think of is to open it up and wire in a second switch and run taht to the dash board. Maybe on a something like a phone Jack lead so it can be removed... cut out a small hole in case and put the scoket, then have a phone lead with a switch on the end...
    Anyway ideas thoughts..
    Constant Bitrate Ill1's Avatar
    Jun 2004
    Woodbridge, VA
    I did exactely what you described. I removed the modem in my laptop and used that space for the connector. Two wires were used for the switch and for the other two I connected a power and ground for an "ON" light. I works pretty well.
    ________________
    ______ILL.1______
    Mar 2005
    Quote Originally Posted by Ill1
    Sweet don't suppose you have any pictures or anything of that bit do you??
    Registered User mpattonm's Avatar
    May 2003
    Czech rep.
    This may be a stupid idea, but check whether your laptop has wake-on-lan feature and if yes, you could use it without need for any kind of modding your laptop.
    Mar 2005
    Quote Originally Posted by mpattonm
    haven't got the laptop yet, how does this work... ect..
  1. Noob question about power supplies
    By Jagojon3 in forum Newbie
    Last Post: 03-09-2005, 12:35 AM
  2. DC-DC Car Power for Mac Mini
    By MikeH in forum MacCar
    Last Post: 02-19-2005, 01:13 PM
  3. Question Regarding Power Antenna
    By temposs in forum Newbie
    Last Post: 11-13-2004, 08:14 PM
  4. Power consumption question
    By S4Per in forum Power Supplies
    Last Post: 02-16-2004, 06:08 PM
  5. Question about power and inverters and all that
    By SBmp3 in forum General Hardware Discussion
    Last Post: 05-01-2003, 12:35 AM
