depends on your vehicle and how healthy your battery is. I think the average is 10v.
I am looking at using a inverter and it can go as low as 10.5 before going into "battery save" mode and shutting off. Is this low enough to survive crank? I searched for an idea of how low the voltage goes but was only able to find something in the FAQ section about minimum input being as low as possible for a PUS, no set number.
Debt as of 1/1/05: $34,354.48
Debt as of July 4, 2007: $0.00 explanation
Total spent on wedding so far: $3885.79
Thanks to everyone for your support.
I'M DEBT FREE!!
depends on your car and the battery you have. There is no simple answer to your question. Just try it and find out.
dammit, I lose
It seems to me that it would depend on the car?
From what people are telling me it's just better to use a DC PSU... I had the same idea you did untill I found a cheaper DC PSU... for the cost of an inverter and normal PSU, it would equal or be more expensive than a ~$50 DC-DC PSU and shutdown controler... then you don't have to worry about cranking or anything.
Worst case about 8V. Typical with oldish battery etc 9-10V. Higher for a good big battery. Also depends if you ahve diesel. The glow plugs and then starting using compression drags the voltage down i believe.
I have a 2004 WRX and new battery, I already have a spare PSU, I have looked at the DC PSUs but I have not found a 300w one yet and am pursuing this route, unless you guys have a link to a PSU that big.
