Results 1 to 9 of 9
Thread: Quickest Way to Move Files
    Dec 2004
    Los Angeles, CA
    Hi, I have about 8 gigs of stuff on my computer that I want to move to my computer in my car. I have a wireless network, but even when Im parked outside my house, it has like barely any signal, so it can't even copy any files. I can't move the computer inside because it is connected to my car and everything. Currently, I am using my Sandisk 1 gb MP3 player to move stuff over, but its taking FOREVER!! Are there any quicker routes? Thanks!
    Nov 2004
    Whittier, CA
    Thing I would do is get a cheap USB enclosure that you can put a spare harddrive into. Now you have quite a bit of space to move the files over. If your mobo supports USB 2.x then your in luck, make sure you buy a usb 2.x enclosure for your spare harddrive. If it only supports 1.x then well, its going to be pretty damn slow.
    Other thing you can do is run a REALLY LONG cable from your router to your car, but thats usually not feasable.
    abstrakONE
    http://www.abstrakone.com
    2000 Dodge Durango Sport [No carputer in it just yet]
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Burn a couple of DVD's?
    you then allso have a backup copy of your MP3's
    Mar 2005
    100Base-T ethernet would be much, much faster than wireless. You'll be fine with a long ethernet cable - unless your caris more than 200m from your house.
    Another factor is going to be the speed of your hard disk drives - even if the data is transferred quickly, the car drive will only be able to write so fast.
    Dec 2004
    Wichita Falls, Texas
    If you are having problems with your wireless you probably need to look @ your wireless AP and/or the wireless NIC in your computer.
    I used to have your problem when I was using my D-Link wireless router. It owuld connect, but would time out on transfers sometimes or just transfer real slowly.
    Now I use Linksys' WRT54G Wireless router and one of their USB wireless G NIC's. I can still transfer files at 54mbps from my neighbors driveway across the street.
    Dec 2004
    Miami, FL
    Why not go buy a cross-over ethernet cable and directly link the two? If it's a laptop, the cable needn't be that long. And if it's a desktop, bring the thing to the nearest window and plug in there.
    Maximum Bitrate TimmyM's Avatar
    Aug 2003
    Federal Way, WA
    My HD is in a removable caddy. When I need to transfer files I grab the HD and plug it into my desktop, then it's just drag and drop.
    Well, He asked for it. WebDog's Avatar
    Los Angeles, CA (West LA)
    you could add a antenna in your car for better range and even maybe add a antenna at your AP...
    1990 Jeep Cherokee
    2000 VW Golf TDI 4dr
    2005 VW GTI MKIV - SOLD
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    Can you move your wireless access point to where you can get a good signal (like near the window)? If you get a long ethernet cable, you could temporarily station it where you can get good reception.
    I know this is no help now, but on carputer number two, I suggest you make the computer easily removable.
    Want to:
  1. Media Files Synchronization
    By IntellaWorks in forum Software & Software Development
    Last Post: 01-20-2005, 09:37 AM
  2. Corrupted VS.net Files
    By BiohazrD in forum Software & Software Development
    Last Post: 11-23-2004, 05:53 PM
  3. Replies: 2
    Last Post: 09-08-2004, 07:07 PM
  4. After I copy files, they are corrupted.
    By Cliff in forum Software & Software Development
    Last Post: 05-17-2003, 09:49 PM
