Results 1 to 10 of 12
Thread: Lilliput TouchScreen hookup problems
    Mar 2005
    SoCal
    Hey everyone..I've been trying to hook up my Lilliput 7" touchscreen to my mini pc, but after installing all the drivers and hooking up all the cables(I believe correctly), still nothing but "no VGA signal"... can anyone help, I've exhausted myself trying all the different possibilities... Thanks in advance!
    BTW, I'm connecting everything using the power from the wall, untill everything is running right and then everything is going into the car. Also, i know the PC is running right because I'm able to run it on a normal monitor.
    Thanks again!
    Variable Bitrate choyak's Avatar
    Jun 2004
    Buena Park, CA
    You probably have the wrong resolution it needs to be 800x600
    Carputer currently 'ghettoed' into car!!!
    EPIA MII-12000
    Ampie Case with rigged extra USB
    Hitachi 60GB
    Holux GPS mouse with iGuidance 2.0
    Netgear WG121 USB WiFi
    Carnetix P1260
    Mar 2005
    SoCal
    tried it..and still the "no VGA signal"..
    Mar 2005
    SoCal
    Please help...
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    1. Don't cross-post. It will only annoy people.
    2. Don't expect an answer in just 2 hours. Sometimes you get one quickly, sometimes it takes some time.
    3. What type of motherboard are you using? When you say you've tried "everything", what does that consist of? Have you tried using a computer that you know has good output?
    Have you read the FAQ in the LCD section that says "Everything you've ever wanted to know about your Lilliput?"
    Want to:
    Mar 2005
    SoCal
    Motherboard:VIA CLE266 + VT8235 Chipset Motherboard
    As far as what I've done.:
    -Connected VGA cables
    -Lowered Resolution and Color Quality to the loweswt possible.
    -Enabled VGA
    -Set to LCD (as states in FAQ of Lilliput)
    The computer I'm using works fine on a CRT, but when it comes to the Lilliput , it's a different story.All I get is a blank screen and sometimes it pops up a "No VGA signal".
    & yes, i have tried everything I found that would relate to this issue in the FAQ as well..
    Any help is appreciated and sorry if I annoyed anyone...just trying to bring the topic to a more specific forum..
    Thanks!
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    Have you tried the Lilliput on a working computer besides the Via?
    Want to:
    Dec 2004
    Miami, FL
    Have you done any modding to the lilli or is it still in the original out-of-the-box form?
    Mar 2005
    SoCal
    Quote Originally Posted by Bugbyte
    No, I guess I should,... but it's because I've been thinking I'm not connecting or enabling something, but I could be wrong
    Quote Originally Posted by maxxell
    Yes I have modded it... This project was orignally started by a buddy of mine that molded the screen, but prior to molding he did check that the screen was functioning. The only thing is that he wasn't able to finish it before he moved out of the country, so now I've taken it over. I've put everything back together exactly how it should be and the screen is working...Since I'm seeing the "no signal" screens.
    Mar 2005
    SoCal
    ttt
  1. 7" Lilliput for sale NO TOUCHSCREEN
    By CDesigns in forum Classified Archive
    Last Post: 05-24-2004, 09:47 PM
  2. Lilliput touchscreen woes/probs
    By Leddy in forum Input Devices
    Last Post: 05-15-2004, 08:42 PM
  3. Lilliput touchscreen problem
    By samc in forum Input Devices
    Last Post: 05-09-2004, 11:12 AM
  4. Trouble dragging on Lilliput touchscreen
    By archimense in forum Input Devices
    Last Post: 05-06-2004, 08:04 PM
  5. lilliput touchscreen problems
    By dominic in forum Input Devices
    Last Post: 01-14-2004, 06:50 PM
