Results 1 to 9 of 9
Thread: headlights on = lights dim = problem?
    Mar 2005
    Seattle, WA
    Hey all. For as long as I can remember, whenever I activate the headlights on my 99 Camry LE L4, my dashboard illumination and digital clock will go dim. Dim enough to be difficult to read in the daytime, but still bright enough to be clearly readable at night. I'm planning to install a second battery (Yellow Optima) and use a inverter to power my carputer, and I'm worried the lights dimming could be a sign of a strain on my power system already. Comments/suggestions?
    Mar 2005
    Heidelberg, Germany (1 mile away from hockenheimer ring :)
    all cars do that!
    God, All this <Matt's System > in an '05 760Li Would kick ***
    Mar 2005
    well most of them, at least our bmw's and buick do
    Feb 2005
    isn't there some kind of wheel/switch (don't know what it's call) that let you control how dim or bright your interior light is? maybe you have that all the way down, that's why it's not so bright.
    Newbie iKenndac's Avatar
    Feb 2005
    Knebworth, UK
    Yup, my car does the same. You can adjust the brightness of the dash lights, but even the maximum is dimmer than without the lights on.
    Constant Bitrate HostileJava's Avatar
    Mar 2005
    Northampton, PA
    All the cars I'e ever own(ed) do that back to 1986, it's a feature not a problem.
    Low Bitrate code-'s Avatar
    May 2004
    Haugsund, Norway
    Quote Originally Posted by HostileJava
    My '84 does too
    1984 BMW 323i (E30)
    [==========] 90%
    EPIA MII10000
    256MB RAM
    40GB 2,5" HD
    Lilliput 7" TS
    Hacked Travla C134
    Haicom CF GPS
    Newbie PCGUY112887's Avatar
    Oct 2004
    Illinois, Near St.Louis
    Why would that be a feature? I guess they assume when you have your lights on... it's dark and turn down the interior lights to make them easier to read?
    My man uses Levitra. Peoples's Avatar
    Dec 2004
    Maryland
    exactly
    PC Components:
    My work log
  1. Red tinted lights, $0 mod!! :D
    By ShinkunoNamida in forum Off Topic
    Last Post: 07-09-2006, 10:53 AM
  2. Hard audio quality problem: Noise / Ground loop?
    By Burat in forum General Hardware Discussion
    Last Post: 09-09-2004, 07:08 AM
  3. Illegal Lighting?
    By lgbr in forum Off Topic
    Last Post: 04-03-2004, 02:26 AM
  4. I can't connect my hard drives + fan problem
    By haisook in forum General Hardware Discussion
    Last Post: 02-03-2004, 10:42 PM
  5. I got a power problem I think
    By Rom in forum General Hardware Discussion
    Last Post: 07-16-2003, 05:00 PM
