Page 1 of 3 123 LastLast
Results 1 to 10 of 30
Thread: Getting a Wire from Battery to Amp
    Mar 2005
    Just riped my car apart and cant find anyway to get the power cable from the battery to the amp, there apears to be no holes which i can run the power cable from the battery to inside the car!
    Is there any tricks or anythink im missing, please help
    Car is a Zafira GSI
    See me in my wet t-shirt. stevieg's Avatar
    Aug 2003
    Warwickshire, UK
    Quote Originally Posted by madmunky
    Car is a Zafira GSI
    Vauxhall Zafira?
    Might be best asking on vauxhall forum, in the ICE section as you have a chance of someone having the same car.
    Ford Focus MP3 : www.stevieg.org/carpc Blog Updated 29 January 2009!
    Car PC Status: Complete - Undergoing Software Redevelopment
    Constant Bitrate HostileJava's Avatar
    Mar 2005
    Northampton, PA
    Most cars have grommets in the firewall that you can pop out to run wires through, if not you can always just drill a hole. Just remember to seal it up so it doesn't start to rust.
    Mar 2005
    Thanks for the replys, in the end i had to use the 12v 150w extra lighter socket in the back which seems to be working ok.
    On a side note though where are the vauxhall ice forums? I looked on vauxhall.co.uk but there doesnt seem to be any forums.
    Raw Wave
    Jun 2004
    On the beach
    I just drilled a new hole in the Pug - all the other cables were too tight to fit anything else through
    Mar 2005
    UK
    you did proberly the easiest thing, another way is to run from any other 12v power supply.. depending how many devices are on that fuse/chain. eg. headunit normally connected with door light.
    My man uses Levitra. Peoples's Avatar
    Dec 2004
    Maryland
    wow, how powerfull is the amp? 150 watts wouldnt cut it for most people
    PC Components:
    My work log
    Mar 2005
    Northampton, PA
    I was thinking that myself but figured some people have to learn the hard way. Hey maybe it's a low current amp design.
    Mar 2005
    Its a Calibar 800w amp, its only temp but so far it seems to be working grate, i added a extra fuse between the amp the lighter socket just in case though.
    Tainted Love Cris's Avatar
    Romania
    Any amp should be powered direct from the battery. There MUST be a hole in the firewall, just look very carefull for it. I found mine pretty hard, but I can assure you it's there. Try and search behind the wipers main block, or something that's where mine was. You will find it. Remeber, you MUST power it from the battery!!!
  1. MPJA - MECI ASTEC DC-DC Converter
    By Luc in forum General Hardware Discussion
    Last Post: 11-22-2004, 09:31 PM
  2. Replies: 4
    Last Post: 10-29-2004, 08:10 AM
  3. Wire Inverter (-) to Battery or Chassis??
    By dodgetimes2 in forum Power Supplies
    Last Post: 06-06-2004, 04:15 PM
  4. Replies: 6
    Last Post: 10-15-2003, 11:50 PM
  5. Main power from battery
    By Sir_Pyro in forum Power Supplies
    Last Post: 01-09-2003, 08:18 AM
