Results 1 to 9 of 9
Thread: Buying a Epia V10000, which case and PSU do I want?
    Mar 2005
    Ottawa, KS
    I want to spend less than $100. I'm going to be hooking it up in the back of my Isuzu Trooper. I'll want it to come on when I turn my key to acc, and off when I take them out. I can work out the power part, I just want to know which case, power control switch, or power supply you suggest. I might be plugging in and external usb bluetooth radio, usb remote, or usb wifi card. It will most likely use a 2.5" HD and probably no CD rom at all.
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    less then $100? that isnt possible unless you steal most of your parts.
    oh wait....less then $100 for just the psu and the case...wasnt reading correctly.
    i say build your own case and buy an m1-atx psu with shutdown control. thats what i did
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
    Mar 2005
    Ottawa, KS
    Then do I want to pull power directly from my battery and put in an inline fuse? Is there some sort of input on the m1 PSU that signals when the vehicle is running and when it isn't?
    Dec 2004
    Los Angeles Ca
    yup, there is an acc. wire
    M10k
    My Car Pc Install
    My Boat Pc worklog
    Mar 2005
    Ottawa, KS
    What OS are you using? And do you have a PCI riser card installed?
    Dec 2004
    Los Angeles Ca
    no pci riser though i have one at my house that i may eventually use, and i'm running xp
    M10k
    My Car Pc Install
    My Boat Pc worklog
    Mar 2005
    Ottawa, KS
    What do you use as your front end to play music/video? Sage or something like that?
    Dec 2004
    Los Angeles Ca
    centrafuse and it is great; easy, clean and stable
    M10k
    My Car Pc Install
    My Boat Pc worklog
    Mar 2005
    Ottawa, KS
    Wow, I hadn't seen that one. It looks great!
  1. Frequently Asked Questions
    By bgoodman in forum The FAQ Emporium
    Last Post: 05-03-2005, 06:25 PM
  2. Replies: 23
    Last Post: 12-14-2004, 11:02 AM
  3. Chyang Fun E-Note EPIA M Compatible Mini-ITX Case
    By tbird2340 in forum Classified Archive
    Last Post: 07-27-2004, 05:35 PM
  4. What to look for in a PSU some info for you
    By cproaudio in forum Power Supplies
    Last Post: 04-04-2003, 01:07 AM
  5. Opus + Epia.. How to get it in the case?
    By ShinkunoNamida in forum Off Topic
    Last Post: 12-28-2002, 10:47 PM
